Manufacturing Solutions
Solid Meshing Wizard
Previous topic Next topic Expand/collapse all hidden text
The Solid Meshing Wizard creates solid (3D) mesh model data decks for injection molding analysis starting from solids. It enables meshing of solids using three different techniques:
Solid map
Volume tetmesh
CFD Tetmesh (tetrahedral mesh with boundary layer)
Mesh created in each solid is placed in a component collector with the name <Comp Name>_<3D Mesh type>#n, where <3DMeshtype> is either of the solidmap, tetmesh or BLmesh and n is an integer represents the ID of the respective solid in the model.
hmtoggle_plus1greySelect Components to be Meshed
When you click on the Solid Meshing Wizard macro, it opens the following dialog. Select the components for meshing, and add it to the respective meshing group. For example, select base and click Solidmap to add it to the Meshed by Solidmap folder.
solid_meshing_wiz_mf01
After selecting the components, click on Next to proceed.
hmtoggle_plus1greyElement Size and Meshing Options Selection
This panel shows three tabs, once corresponding to each meshing method. Solid Map and Tetra Mesh tabs list the selected components and respective solids with their IDs. It also shows the recommended element size for each solid as shown in the below image. This size can be edited.
solid_meshing_wiz_mf02
The CFD Mesh tab will display additional meshing parameters relevant to creating boundary layer mesh in addition to the element size, as shown in the below image. Please refer to the help on CFD BL meshing.
solid_meshing_wiz_mf03
Use this tab to select and specify the surfaces to be considered as inlet/outlet/symmetry surfaces for the purpose of creating a boundary layer mesh. Refer to the CFD mesh help for better understanding of the above mesh parameters.
Complete the mesh by clicking Mesh.
