Manufacturing Solutions
Run Panel of the Selected Project
When a project is loaded; its Run panel will be populated. In this panel you will be able to see the contents of the project.  This process will automatically collapse the project tree to maximize the viewing area of the tab.
project_browser_run
Run Panel Functionalities
Control button - Expand/shrink or toggle the Run panel
Icon Bar - This contains icons for New Run, Refresh Run, and Delete Run
Field which shows the current location of the selected project
Right-click on the project folder to create a new run or open an explorer window to show the folder.
project_browser_run_02
Right-click on the run folder to load the run into the wizard and perform related operations.
project_browser_run_04
If there is no model file inside the run folder, the right-click menu will allow to you select a model file. If there is at least one model file inside the run folder, you will be prompted to select the model file.
project_browser_run_03
Run Panel Menu
Right-clicking on the run populates the context sensitive menu, as shown below.
project_browser_run_05
New Run – Create a new run folder. Clicking the fileNew-24icon will open the same functionality. However, this option is only available from within the project. Creating a run folder inside of another run folder is not allowed.
Save Run As – Saves the run under a different name. The folder will automatically be created.
Refresh Run – Refreshes the Run panel.
Delete Run – Deletes the selected run.
Show In Explorer – Opens the windows explorer dialog opened to the appropriate location. This option is available only for Windows platforms.
Load Model File – Loads the selected model.
Load Run into Wizard - This option is available only if there is one model in the selected run folder. Clicking on this option loads the model file to the wizard.
Edit Settings – Opens the Project Settings dialog
