Manufacturing Solutions
Project Browser Context Menus
Right clicking on a non-project folder displays the following menu:
project_browser_context
Right clicking on an undetected folder displays the following menu:
project_browser_folder_menu
Right clicking on the project folder populates the context sensitive menu, as described below:
If the loaded project contains only one .hm file, then the browser will create a new run folder and copy that model file inside the run folder.
If the selected project folder is empty, right click on the folder and click Select model file.
If there are one or more .hm files in the project folder, right click on the folder and click on a suitable model from the sub-menu.
If the project folder has both run folders and .hm files, right click on the folder and click Load Project.
For example, BilletSkinTracking is a project folder that contains run folders and models in it. When you right-click on it, you will be prompted as shown in the picture below.
project_tree_load_project
Various options available in the Project Browser menus are explained below.
New Project – Creates a new project. Type in a new project name and press ENTER. Clicking the fileNew-24icon will open the same functionality.
New Non-Project – Creates a new non-project. Type in a new non-project name and press ENTER. Clicking the fileNewDocument-24 icon will open the same functionality.
Mark folder as – An undetected folder can be marked as Non-project folder or a project folder. A non-project folder can be marked as HX project folder. A project folder can be marked as non-project folder. Right-click on the folder and click on suitable sub-menu.
Copy Project – Copies contents in the current project to a selected location.
Refresh Project – Refreshes the Project panel page.
Delete Project/Non-project – If the selected folder is project folder, then right-click on the folder and click Delete Project. If the selected folder is non-project folder, then right-click on the folder and click Delete Non-project folder. Click on the suitable folder and then click on delete-24 icon to perform the same functionality.
Load Project – Loads the selected project to the next panel.
Show In Explorer – Opens the windows explorer dialog opened to the appropriate location. This option is available only for Windows platforms.
Edit Settings – Opens the Project Settings dialog.
