Manufacturing Solutions
HX-1001: Geometry Cleanup
Previous topic Next topic Expand/collapse all hidden text
In this tutorial, you will learn about preparing the geometry for meshing. This process involves organizing, editing, and creating missing surfaces to make the model an enclosed volume. The enclosed volume of surfaces is used to create solids. The solids can then be connected to each other by creating the shared surfaces. These connected solids can be meshed either manually or using Plate Meshing Wizard inside the Polymer Extrusion template.
Geometry cleanup is done to achieve the following:
Correct any errors in the geometry from import
Create the simplified part needed for the analysis
Mesh a part all at once
Ensure proper connectivity of mesh
Obtain a desirable mesh pattern and quality
hmtoggle_plus1greyFiles
The model files for this tutorial are located in the file mfs-1.zip in the subdirectory \hx\MetalExtrusion\HX_1001. See Accessing Model Files.
To work on this tutorial, it is recommended that you copy this folder to your local hard drive where you store your HyperXtrude data, for example, “C:\Users\HyperXtrude\” on a Windows machine. This will enable you to edit and modify these files without affecting the original data. In addition, it is best to keep the data on a local disk attached to the machine to improve the I/O performance of the software.
hmtoggle_plus1greyStep 1: Launch HyperXtrude
1.Select Start Menu > All Programs > Altair Hyperworks > Manufacturing Solutions > HyperXtrude to launch the HyperXtrude User Interface. The User Profiles window appears with Manufacturing Solutions as the default application.  The HyperXtrude radio button is also selected by default.
user_profile_pp
2.Select Polymer_Processing from the HyperXtrude drop-down menu.
3.Click OK.
hmtoggle_plus1greyStep 2: Import the IGES geometry file into the current HyperMesh session
1.Click the Import Geometry icon fileImportGeometry-24 .
2.Set the File Type field to Auto Detect and click the Select Files icon fileOpen-24.
3.Select the file: HX_1001.igs.
4.Click Import to read the die geometry.
5.Click Close to close the Import tab.
6.Take a few moments to observe the model using the different visual options available in HyperMesh (rotation, zooming, etc.) and switching between Wireframe Geometry icon visualizationGeometryWireframe-16 and Shaded Geometry and Surface Edges visualizationGeometryShadedWithEdges-16 icon.
HX_1001_01
hmtoggle_plus1greyStep 3:  View the model to evaluate its integrity
1.Observe where the model has incorrect connectivity and missing or duplicate surfaces.
2.From the main menu, click edge edit.
3.Note that the surface edges are now colored according to their topology status. This occurs because the Geometry Color option visualizationGeometryColorMode-18 is set to Auto.
4.Click the Wireframe Geometry icon visualizationGeometryWireframe-24 and the Shaded Geometry & Surface Edges visualizationGeometryShadedWithEdges-24 icon to explore the different display modes.
5.The toolbar contains icons that control the display of the surfaces and surface edges. Surfaces can be shaded with or without edges, or wireframe. Click the icons to access the drop down menu for additional options. Place your mouse over the cursor to view a description of the button’s functionality.
6.Set the display mode back to Wireframe Geometry visualizationGeometryWireframe-24.  The figure below shows all the edges displayed according to their topology.
HX_1001_01_wireframe
Note: In Topology color mode, each color represents different topological mode:
Free edge (red): The edge is owned by one surface. On a clean model, free edges appear only along the outer perimeter of the part and internal holes. Free edges that appear between two adjacent surfaces indicate the existence of a gap between the two surfaces.
Shared edge (green): The edge is owned by two adjacent surfaces.  When the edges between two adjacent surfaces are shared (green), there is no gap or overlap between the two surfaces, and they are geometrically continuous. The automesher always places seed nodes along their length and will produce a continuous mesh without any gaps along that edge.  The automesher will not construct any individual elements that cross over a shared edge.
Suppressed edge (blue): The edge is owned and shared by two adjacent surfaces but it is ignored by the automesher.  They are blue dotted lines by default. Like a shared edge, a suppressed edge indicates geometric continuity between two surfaces but, unlike a shared edge, the automesher will mesh across a suppressed edge as if it were not even there.  The automesher does not place seed nodes along their length and, consequently, individual elements will span across it.  By suppressing undesirable edges you are effectively combining surfaces into larger logical meshable regions.
Non-manifold edge (yellow): The edge is owned by three or more surfaces. They typically occur at "T" intersections between surfaces or when 2 or more duplicate surfaces exist. The automesher always places seed nodes along their length and will produce a continuous mesh without any gaps along that edge. The automesher will not construct any individual elements that cross over a nonmanifold edge.  These edges cannot be suppressed and can sometimes be indication for duplicated geometry.
7.Click the Visualization icon visualization-24 and select the Topology icon topology_icon.
Visualization controls the display of the surfaces and surface edges. Surfaces can be shaded or wireframe. The check boxes within this menu turn the display of the different edge types and fixed points (surface vertices) on or off.
8.Clear all the check boxes except the Free check box. Now only the free edges should be displayed.
HX_1001_01_freeedgesonly
9.Observe the free edges and make a mental note of where they are. The free (red) edges show where there is incorrect connectivity or gaps.
10.Note the locations where there are closed loops of free edges.  These are locations that probably have missing surfaces or are not equivalenced.
11.Rotate, zoom and pan to locate any errors in the geometry.
12.Make a mental note of the areas to be worked on.
13.Click return to close the panel.
hmtoggle_plus1greyStep 4: Rename the components
1.In the Model browser, expand the Components folder.
2.Right-click on the component lvl1 and select Rename.
3.Enter the new name as Manifold0.
4.Repeat steps 2 and 3 to rename the component as follows:
lvl2 to Manifold1
lvl3 to Manifold2
lvl4 to Manifold3
lvl5 to Manifold4
lvl6 to Manifold5
lvl7 to Manifold6
Note:Use the mesh and surface icons next to the component names to control the display. Click them to turn the display on and off.
5.Right-click again on Manifold0 and select Make Current. This sets the Manifold0 component as the current component collector. Any newly created surfaces will be put into this collector.
hmtoggle_plus1greyStep 5:  Cleanup the geometry of one component at a time
1.Click on Isometric View icon viewAxisOrientationIso-24 on the tool bar.
2.Click on translate on main menu.
3.Change the entity selector to comps. Change the direction to y-axis and magnitude to 100.00. Select collectors manifold0, Manifold2, Manifold4, Manifold6 and click translate+.
HX_1001_02
4.Click return.
5.In the Model browser, right click on Components and select Hide.
6.Right click on Manifold0 and select Show. Right click on it again and select Make Current.
7.Click on surfaces on the main menu.
8.Clear the Keep tangency check box.
The keep tangency option looks at surfaces attached to the selected edges and tries to create a surface tangent to them.  This helps to form a smooth transition to the surrounding surfaces.
9.Ensure the auto create (free edges only) check box is selected.
The auto create option simplifies the selection of the lines bounding the missing surface. Once a line is selected, HyperMesh automatically selects the remaining free edges that form a closed loop, and then create the filler surface.
10.Ensure the entity type is set to lines.
11.Zoom into the area indicated in the following image.
12.Click on the edge in red color and click create. Notice that a surface is created, making Manifold0 an enclosed volume.
13.Click solids on the main menu. Select all the surfaces and click create to create the solids.
HX_1001_03        HX_1001_03b
hmtoggle_plus1greyStep 6:  Cleanup the geometry of Manifold1
1.Hide Manifold0 and show Manifold1 and make it current by following step 6 above.
2.Press F5 to open the Mask panel.
3.Change the entity type to surfs. Select one half of the Manifold1 and click mask to hide that part.
4.Click return.
5.In the main menu, click delete to open the Delete panel.
6.Change the entity type to surfs.
7.Select the surface shown in the image below and click delete entity.
8.Click return.
HX_1001_04 HX_1001_04b
9.Click surfaces on the main menu to open the Surfaces panel.
10.Make sure the entity type is set to lines.
11.Select Auto create (free edges only) and clear Keep tangency. Click on the free edges (red). Notice that the surface is created.
12.Press F5 and click on unmask all.
13.Repeat steps 3-11 to delete and create the corresponding surface on the other half of Manifold1.
14.Click edge edit on the main menu.
15.Select the replace radio button.
16.Replace one of the lines with the other line by properly selecting the moved edge and retained edge. If necessary increase the tolerance to 0.6. After this step a shared edge (yellow) will be created between the two parts.
17.Click return.
18.Click solids on the main menu. Select all the surfaces and click create to create the solids.
HX_1001_05
hmtoggle_plus1greyStep 7:  Cleanup the geometry of Manifold2
1.Hide Manifold1 and show only Manifold2 and make it current by following step 6 above.
2.Rotate the geometry and notice the two missing surfaces.
3.Click surfaces on the main menu.
4.Make sure the entity type is set to lines. Select the Auto create (free edges only) option.
5.Clear Keep tangency. Click on the free edges (red).
HX_1001_06
6.Notice that the surfaces are created. Click return.
7.Click solids on the main menu. Select all the surfaces and click create to create the solids.
HX_1001_07
Now Manifold0, Manifold1 and Manifold2 are clean. The next step is to clean Manifold3.
hmtoggle_plus1greyStep 8:  Cleanup the geometry of Manifold3
1.Hide Manifold2 and show only Manifold3 and make it current by following step 6 above.
2.Click edge edit on the main menu and notice that there are several geometry errors.
HX_1001_08
3.Clean one of the two sub parts at a time, starting with the right side part.
Zoom into the region shown below. Click replace on the Edge Edit panel to move the right side line on to the left side line.
HX_1001_09
4.The gap is about 0.5 between the lines. Click yes if the following window shows up.
HX_1001_09_confirmation
5.Carefully select the lines for moved edge and retained edge such that surfaces on both sides share at a single edge as shown in the picture below.
HX_1001_10
6.Now clean up the left side part. Zoom into the region shown below.
HX_1001_11
Use the replace option on the Edge Edit panel to move the left side line on to the right side line such that surfaces on both sides share at a single edge as shown in the picture below.
HX_1001_12
7.Still there are geometry errors in top region. Zoom into that region.
8.Select the equivalence radio button and click the equiv free edges only check box.
9.Select the outside line and click equivalence. Those two lines will be equivalenced.
HX_1001_13
Now Manifold3 is completely clean.
HX_1001_14
10.Click solids on the main menu. Select all the surfaces and click create to create the solids.
HX_1001_15
hmtoggle_plus1greyStep 9:  Cleanup the geometry of Manifold4
1.Hide all the components and show only Manifold4 and make it current by following step 6 above.
2.Click edge edit on the main menu to observe the geometry errors.
3. Notice that except one part all the parts are already clean.
HX_1001_16
4.Zoom in the region where corrections are necessary.
5.Observe that red and green lines are overlapped on the outer edges. This indicates a possible duplicate surface.
6.Click return to exit the Edge Edit panel.
7.Click delete on the main menu. Select the outer surface as shown in the picture below. Click delete entity. The duplicate surface will be deleted.
HX_1001_17a        HX_1001_17
8.Some errors still persist. Delete the two surfaces as shown in the picture below and recreate them. This will completely clean Manifold4.
HX_1001_18 HX_1001_18b
9.Click solids on the main menu. Select all the surfaces and click create to create the solids.
HX_1001_19
hmtoggle_plus1greyStep 10:  Cleanup the geometry of Manifold5 and Manifold6
1.Observe that there are no errors in Manifold5 geometry.
HX_1001_20
2.Click solids on the main menu. Select all the surfaces and click create to create the solids.
HX_1001_21
3.Manifold6 geometry is also clean except one unwanted edge. Suppress that edge using the suppress option on the Edge Edit panel.
HX_1001_22
HX_1001_23
4.Click solids on the main menu. Select all the surfaces and click create to create the solids.
HX_1001_24
5.Click translate on main panel.
6.Change the entity selector to comps. Change the direction to y-axis and magnitude to 100.00. Select collectors, manifold0, Manifold2, Manifold4, Manifold6 and click translate-. All the components will be aligned.
HX_1001_25
Return to Polymer Processing Tutorials
