Manufacturing Solutions
HX-1000: Overview of Polymer Processing Tutorials
Altair HyperXtrude is packed with features for extensive support polymer processing analysis and similar problems. The goal of these tutorials is to enable you to use HyperXtrude for your analysis. If a specific tutorial you need is not available in the release, please contact hxsupport@altair.com. It may be already available, however, not included in the release.
HyperXtrude is used to analyze following classes of problems. These analyses include the study of material flow, heat transfer, and free surface/material interface/tool deformation (depending on the context).
Film and sheet extrusion
Profile extrusion
Coextrusion
Runner balancing
Paste extrusion
Flow in mixing devices
Fiber spinning
Flow in single and twin screw extruders
In general, HyperXtrude can be used to model the material flow in arbitrary three-dimensional conduits. In order to facilitate these analyses, HyperXtrude supports a variety of material models. These models can be function of shear rate, temperature and time (thixotropy). Models supported for non-Newtonian flow in HyperXtrude are:
Power law model
Carreau Yasuda model
Cross model
Modified Cross model
Regularized Herschel-Bulkley model
User defined material model
HyperXtrude uses Casson model for thixotropy and supports four different temperature dependency functions.
Numbering Convention
Number
Topic
1000
Overview of polymer processing tutorials
1001-1049
Geometry related - Importing CAD, Geom Cleanup, Solid Editing
1050-1099
Mixing and pumping devices
1100-1149
Film and Sheet Extrusion
1150-1199
Profile extrusion
1200-1249
Coextrusion, Extrusion with metal inserts, Wire coating etc.
1250-1299
Post extrusion operations such as calibrators, etc.
1300-1349
Tool deflection analysis
1350-1399
Morphing, optimization, etc.
1400-1449
Material properties
1450-1499
Special topics such as, runner balancing etc.
1500-1599
Post processing
Return to Polymer Processing Tutorials
