Manufacturing Solutions
HX-1251: Calibrator Analysis
Previous topic Next topic Expand/collapse all hidden text
The model files for this tutorial are located in the file mfs-1.zip in the subdirectory \hx\MetalExtrusion\HX_1251. See Accessing Model Files.
To work on this tutorial, it is recommended that you copy this folder to your local hard drive where you store your HyperXtrude data; for example, "C:\Users\HyperXtrude" on a Windows machine. This will enable you to edit and modify these files without affecting the original data. In addition, it is best to keep the data on a local disk attached to the machine to improve the I/O performance of the software.
hmtoggle_plus1greyStep 1: Load and inspect the model
1.Load the model HX_1251.hm. The model is already meshed.
HX_1251_01
hmtoggle_plus1greyStep 2: Assign materials
1.To select and assign the suitable materials, click Material Data on the Utility menu.
2.Select the material PVC_Generic and click Add.
HX_1151_10
3.Right-click on PVC_Generic and click Assign Material.
HX_1154_04
4.Assign the material to suitable components by clicking on the respective component checkboxes. Click Update to complete the material assignment.
5.Repeat Steps 2-4 to assign the material H_13(Tool_Material) to the components CalibratorBottom3D and CalibratorTop3D.
HX_1251_05
6.Set the Deformation type as Stationary Elastic for components that have Tool Material assigned to them.
HX_1251_06
7.Click on Close to exit the Material Data window.
hmtoggle_plus1greyStep 3: Define and assign boundary conditions
1.In the Utility menu, under BCs, click Create/Edit.
2.Click on BCs to create a new boundary condition.
3.Enter Inlet in the Name field.
4.Set the Type field to Inflow, and the Material field to PVC_Generic(Polymer).
5.Click Create to set the parameters for this BC.
6.Set the following fields, and leave the others with their default values:
ZVelocity = 50 mm/s
Temperature = 450 deg/C
7.Click Create Faces to assign the BC face elements for the BC.
8.Turn on the respective 3D component and pick one element on the face and click proceed.
HX_1251_07
9.Repeat steps 3 - 8 to create another boundary condition:
Name
ProfileFreeBC
FreeSurface
Material
10. Click Create to set the parameters for this BC. Create another one, using the following parameters:
Heat Transfer Type
Convection
Convection Coefficient
10 W/m^2-degC
Convection Temp
40 degC
11.Pick a few elements on ProfileIn3D and ProfileOut3D to create ProfileFree BC.
HX_1251_08
12.Repeat steps 3 - 8 to create another boundary condition:
Name
CalibratorOuter
ToolSurface
Material
H_13 (Tool)
13.Click Create to set the parameters for this BC. Use the following parameters:
Heat Transfer Type
Convection
10 W/m^2-degC
Convection Temp
40 degC
14.Pick a few elements on the outer face of CalibratorTop3D and CalibratorBottom3D to create CalibratorOuter BC.
HX_1251_10
CalibratorOuter BC
15.Repeat steps 3 - 8 to create another boundary condition:
Name
ProfileCalibrator
SolidFluidInterface
Material
16.Click Create to set the parameters for this BC. Use the following parameters:
Friction Model
SlipVelocity
Frict Coefficient
100
Contact Type
Mismatched
Contact Surface
CalibratorProfile
Heat Transfer Coeff
3000 W/m^2-degC
17.Pick a few element on the outer face of Profile3D.
HX_1251_09
ProfileCalibrator BC
18.Repeat steps 3 - 8 to create another boundary condition:
Name
CalibratorProfile
SolidFluidInterface
Material
H_13 (Tool)
19.Click Create to set the parameters for this BC. Use the following parameters:
Friction Model
SlipVelocity
Frict Coefficient
100
Contact Type
Mismatched
Contact Surface
CalibratorProfile
Heat Transfer Coeff
3000 W/m^2-degC
HX_1251_11
CalibratorProfile BC
20.Repeat steps 3 - 8 to create another boundary condition:
Name
Pipes
ToolSurface
Material
H_13 (Tool)
21.Click Create to set the parameters for this BC. Use the following parameters:
Heat Transfer Type
Convection
Convection Coeff
1000 W/m^2-degC
Convection Temp
40 degC
22.Pick a few elements in the interior circular regions of CalibratorTop3D and CalibratorBottom3D.
HX_1251_12
Pipes BC
23.Repeat steps 3 - 8 to create another boundary condition:
Name
Outlet
Outflow
Material
24.Click Create to set the parameters for this BC. Use the following parameters:
Pressure
Checkbox should be activated
25.Pick a few elements on the Maximum Z face of the Profile3D component.
HX_1251_13
Outlet BC
hmtoggle_plus1greyStep 4: Set process parameters
1.Click Parameters on the Utility menu.
2.Click on the User Commands tab and write the commands solve and exit under Footer data.
HX_1152_07
3.Click Close to exit the Parameters dialog.
The model setup is complete; it is ready to be exported and solved.
Return to Polymer Processing Tutorials
