Manufacturing Solutions
Export/Import Bearing Control Points
Bearing control points are exported in the following format:
#CPSTART
This comment enables importing the profile back to HyperMesh and will be ignored by the HX solver
#CP P0 P1 P5 . . . . .
#CPEND
On import, the control points are read from the line “#CP P0 P1 P5 . . .” The bearing profile is drawn from these control points. To add control points manually, use the above format in the .grf file.
