Manufacturing Solutions
Export Bearing Optimization Points
In HyperXtrude, the bearing optimization data is exported. In order to enable this operation, set Bearing Optimization to Yes and click on Update.
edit_boundary_conditions
The format of exported data:
# Pt  CPID NodeID  X_Coord  Y_Coord  Z_Coord  Brg_Length_Min   Brg_Length_Max  DV_Tag
Import of bearing optimization data is not supported.
