Manufacturing Solutions
Bearing Optimization
In HyperXtrude, you can edit the DV data. Turn on the Edit DV Tag to proceed to the Bearing Optimization page.
edit_dv_tag_3
Optimized Points:
Click Pick to select the optimized control points.
Reset will clear the selections
Show/Hide turns on/off optimized points
Fixed Points:
Click Pick to select the fixed points
Show/Hide turns on/off fixed points
Dependent Points Table:
Selected optimized points will be populated in the table. For each optimized point, pick the dependent points.
Click Pick to select dependent points for the optimized point. If points are selected, the Pick button will be highlighted in green.
Reset will clear the selections of dependent points that are dependent on the respective optimized point.
Show/Hide turns on/off dependent points dependent on respective optimized point.
edit_dv_tag_2
Back will take you to the previous page.
Click Display All Pts to view all the selected points.
Click OK to complete the bearing profile.
bearing_profile_y_x
HyperMesh interpolates the bearing length at nodes in between two control points and displays the bearing profile on the screen. This profile is used in the calculations.
bearing_profile_x_y_z
