NVH Menu
The NVH menu provides you with access to various NVH utilities.
- From the File menu, select . The Preferences dialog is displayed.
- From the Preferences dialog, select NVH-Utilities and click Load. The NVH menu is added and displayed on the メニューバー.
図 1.
From the NVH menu, you can select the following options:
