Rapidly change the shape of the FE mesh without severely sacrificing the mesh quality and create, edit, and apply
shapes for subsequent design optimization studies.
Morph constraint entities restrict the movements of nodes or force compliance with dimensional requirements during morphing.
These constraints are always valid for all available morphing approaches.
Morph volume entities are highly deformable six-sided prisms which surround a portion of the FE mesh, and can be used
to manipulate a mesh by manipulating the shape of the morph volume.
Use the Morph Volumes: Enclose tool to create morph volumes with rectangular or circular shapes. Enclosed mesh and connectors are automatically
registered to the enclosing volumes by default.
Use the Morph Volumes: Split/Combine tool to split morph volumes using a single or multiple locations along an edge, combine adjacent morph volumes along
shared faces, join pairs of separate morph volumes, or equivalence any number of morph volume faces using a
search distance.
Use the Morph Volumes: Register tool to review and edit the contents of morph volumes. Only registered contents will morph when morphing morph volumes.
Entities that can be registered to morph volumes are nodes and connectors.
The Design Space environment is dedicated to topology optimization model build and setup. It facilitates rapid model creation by generating
the voxel design space for a number of different use cases.
Many essential utility tools using HyperWorks-Tcl have been developed over the years to support Aerospace customers. A few tools have been collected and upgraded to
be compatible with this release.
volumes. Only registered contents will morph when morphing morph volumes. Entities that can
From the Morph ribbon, click the Morph Volumes > Register tool.
Leave the morph volumes selector empty to review and edit contents of all morph
volumes at once (automatic), or select specific volumes to review and
edit.
Use the Registered selector to edit registered nodes or
connectors
Nodes can be manually registered to individual selected volumes, while
connectors are always registered to volumes physically enclosing them
(automatic).
Click Register on the guide bar
to update the selected entities.
