Enclose Morph Volumes
Use the Morph Volumes: Enclose tool to create morph volumes with rectangular or circular shapes. Enclosed mesh and connectors are automatically registered to the enclosing volumes by default.
View new features for HyperWorks 2021.
Set up your sessions in HyperWorks and create report templates.
Rapidly change the shape of the FE mesh without severely sacrificing the mesh quality and create, edit, and apply shapes for subsequent design optimization studies.
Morph constraint entities restrict the movements of nodes or force compliance with dimensional requirements during morphing. These constraints are always valid for all available morphing approaches.
Use the Free tool to morph mesh by moving nodes, faces, and edges or by mapping to geometry.
Use the Proximity tool to morph mesh using a simple distance or perturbation value around selected nodes, faces, or edges.
Morph volume entities are highly deformable six-sided prisms which surround a portion of the FE mesh, and can be used to manipulate a mesh by manipulating the shape of the morph volume.
Use the Morph Volumes: Move tool to morph or adjust morph volumes by moving vertices/handles, edges, and faces with graphical manipulators.
Use the Morph Volumes: Split/Combine tool to split morph volumes using a single or multiple locations along an edge, combine adjacent morph volumes along shared faces, join pairs of separate morph volumes, or equivalence any number of morph volume faces using a search distance.
Use the Morph Volumes: Register tool to review and edit the contents of morph volumes. Only registered contents will morph when morphing morph volumes. Entities that can be registered to morph volumes are nodes and connectors.
Shapes are collections of perturbations from the initial configuration of the FE mesh before the morph.
Domain entities divide the model into different domains during morphing.
Handle entities control the shape of domains during morphing.
Symmetry entities define planes of symmetry within a model so that morphs can be applied in a symmetric fashion.
HyperMesh composites modelings.
The Design Space environment is dedicated to topology optimization model build and setup. It facilitates rapid model creation by generating the voxel design space for a number of different use cases.
Many essential utility tools using HyperWorks-Tcl have been developed over the years to support Aerospace customers. A few tools have been collected and upgraded to be compatible with this release.
Use the marine tool set to streamline the creation of properties and 1D stiffener mesh using the info read from Marine CAD tools.
Use Squeak and Rattle Director tool set to create evaluation lines, evaluate them and optimize the interfaces to eliminate squeak and rattle issues.
As you select entities, morph volumes are automatically created around them using the current settings. You can keep adding/removing entities or modifying the settings and the volumes will update automatically until you exit the tool or click Enclose.
Global and Best Fit types create automatically oriented rectangular volumes.
