HyperGraph hgradioss External Reader
Description Supports Does Not Support
Reads Radioss T01 files (result files generated by the solver) into HyperGraph. Global Variables
PARTS
PROP
MAT
NODE
BRIC
QUAD
SHEL, SH3N
BEAM
TRUSS
SPRING
ACCEL
SECTIO
CYL_JO
MONV
RWALL
RBODY
INTER
SUBS
NSTRAND
Usage
To run from the command prompt:
hgradioss(.exe) –f fileT01 outfile
To run in HyperGraph:
By default, this reader is registered. If not, please register it before reading T01 files directly into HyperGraph. It is located in the HWDIR\externalreaders\ directory.
Notes
  • HyperGraph supports T01, T01a, ….. T01i time history files
  • HyperGraph supports _0001.thy, _0001a.thy, …._0001i.thy time history files
  • HyperView support #T01, @T01 files from RAD2NOISE tool
  • HyperView support .lst files from HELIOSS
