FiberSim Reader
The FiberSim reader is supported for Nastran and OptiStruct user profiles.
Supported Entities
Entities supported by the FiberSim HDF5 reader.
Plies
Name, thickness, and fiber orientation information is directly read and mapped as a Ply entity. Plies that point to woven and stack materials are split/separated into multiple plies with half the thickness and correct orientation angles. These split ply names always have _1 and _2 suffix in them for each identification.
Date Map/Table
Data map with element set (ply shapes), material orientation angles (orient1 , orinet2 , draping corrections) thickness corrections, reference direction and normal information for each ply is preserved/mapped in the table entity, therefore each ply has a table associated with it. Nodes and elements are not created in the database from FiberSim triangulation data to define ply shapes. Instead, it preserves this information in a table so that when these plies are mapped (realized) on actual good mesh, HyperWorks uses this triangular information to define the ply boundary and extract the actual elements.
Laminates
One laminate per HDF5 component with all the ply sequence preserved as per layer_id value.
Materials
Material names and their mechanical properties are read and mapped to solver cards automatically depending on the user profile loaded while importing the model. Currently mechanical properties such as E1, E2, E3, G12, G13, G23, Alpha1, Alpha2 and Alpha_ref temperature are mapped to solver material attributes.
Rosette/Systems
All the system definitions available in the HDF5 file will be imported into one system collector. Currently HyperWorks does not preserve the ply and system relation.
