CATIA Composites Link Reader
Use the CATIA Composites Link option to import drape data. This method is separate from the CATIA reader, where drape data is not imported.
You need to use the CATIA Composites Link (Simulayt) module and export a HDF5 file and then use that to import in HyperWorks using the CATIA Composites Link connection. This is similar to the FiberSim reader.
