Properties
Property entities define and store 1D, 2D, and 3D property definitions for a model.
Properties do not have a display state in the modeling window. You can color the model according to the colors assigned to each property, which is based on element property relationships, by changing the color mode to property.
Element property relationships are dependent on the solver interface. In general, when a component is assigned a property, that property assignment is applied to all elements collected by that component. The method of assigning properties at the component level is therefore referred to as indirect property assignment. Direct property assignment is performed directly on the elements themselves, typically via a property assignment. Direct property assignments always take precedence over indirect property and material assignments.
Abaqus Cards
Card Description
*ADAPTIVE CONTROLS Controls various aspects of the adaptive meshing and advection algorithms applied to an adaptive mesh domain.
*BEAM ADDED INERTIA Define additional beam inertia.
*BEAM GENERAL SECTION Specify a beam section when numerical integration over the section is not required.
Note: Only one *BEAM GENERAL SECTION card is output per component, therefore the beam elements in each component must have the same cross-sectional properties.
*BEAM SECTION Specify a beam section when numerical integration over the section is required.
Note: Only one *BEAM SECTION card is output per component, therefore the beam elements in each component must have the same cross-sectional properties.
*COHESIVE SECTION Specify element properties for cohesive elements.
*CONNECTOR SECTION Specify connector attributes for connector elements.
Note:
The following types are supported:
Standard template:
Explicit template:
All listed above, as well as ROTATION-ACCELEROMETER
*CONTACT DAMPING Define viscous damping between contacting surfaces.
Note: This card is a sub-option in the *SURFACE INTERACTION card image.
*DASHPOT Define dashpot behavior.
Note: Only one *DASHPOT card is output per component, therefore the spring elements in each component must have the same properties.
When the *DASHPOT card is written for DASHPOT1 elements, both dof1 and dof2 are written, but Abaqus only reads dof1.
For DASHPOTA elements, choose the DASHPOTA option in the *DASHPOT card image.
*ELEMENT PROPERTIES
*EULERIAN SECTION Define properties of Eulerian continuum elements, including the list of materials that may occupy the elements.
*FASTENER (SPOT WELD) PROPERTY Prescribe mesh-independent fastener properties.
*FLUID BULK MODULUS Define compressibility for a hydraulic fluid.
Note: This option is used to define compressibility for the hydraulic fluid model. It can only be used in conjunction with the *FLUID BEHAVIOR option or the *FLUID PROPERTY option.
*FLUID DENSITY Specify hydrostatic fluid density.
Note: This option is used to define the reference fluid density for fluid cavities. It is only applicable for hydraulic and pneumatic fluids, and should not be used for user-defined fluids. The *FLUID DENSITY option can only be used in conjunction with the *FLUID BEHAVIOR option or the *FLUID PROPERTY option.
*FLUID EXPANSION Specify the thermal expansion coefficient for a hydraulic fluid.
Note: This option is used to define thermal expansion coefficients for the hydraulic fluid model. It can only be used in conjunction with the *FLUID BEHAVIOR option or the *FLUID PROPERTY option.
*FLUID PROPERTY Define properties for hydrostatic fluid elements.
*FRICTION Specify a friction model.
Note: This card is a sub-option in the *SURFACE INTERACTION card image. It is also supported as a separate card image to allow for it to be used as a sub-option of the *CONNECTOR FRICTION card (in *CONNECTOR BEHAVIOR).
*GAP Specify clearance and local geometry for GAP-type elements.
Note: Only one *GAP card is output per component, therefore the gap elements in each component must have the same properties.
Not available in the Explicit template.
*GASKET SECTION Specify element properties for gasket elements.
Note: Not available in the Explicit template.
*ITS Define the properties for ITS-type elements.
*JOINT Define properties for JOINTC elements.
Note: Only one *JOINT card is output per component, therefore the spring elements in each component must have the same properties.
The *SPRING and *DASHPOT cards in the *JOINT property behave the same way as the individual cards mentioned above. See the How do I section below for more information.
*M1 Define the first bending moment behavior of beams.
*M2 Define the second bending moment behavior of beams.
*MASS Specify a point mass.
Note: Only one *MASS card is output per component, therefore the mass elements in each component must have the same properties.
*MEMBRANE SECTION Specify section properties for membrane elements.
*NONSTRUCTURAL MASS Specify mass contribution to the model from nonstructural features.
Note: Only available in the Explicit template.
*PHYSICAL CONSTANTS Specify physical constants.
*REBAR LAYER Reinforcement definition
Note: The keyword is available in the card image of the SHELL SECTION (homogeneous and composite), MEMBRANE SECTION, and SURFACE SECTION.
*RIGID BODY Define a set of elements as a rigid body and define rigid element properties.
Note: For Analytical Rigid Surfaces, the ANALYTICAL SURFACE parameter should point to the corresponding ANALYTICAL_RIGID_SURFACE group from the card image of the *RIGID BODY card.
*ROTARY INERTIA (no longer listed on panel) Define rigid body rotary inertia.
Note: Only one *ROTARY INERTIA card is output per component, therefore the ROTARY1 elements in each component must have the same properties.
*SECTION CONTROLS Specify section controls.
*SHELL GENERAL SECTION Define a general, arbitrary, elastic shell section.
*SHELL SECTION Specify a shell cross-section.
*SOLID SECTION Specify element properties for solid, infinite, acoustic, and truss elements.
*SPRING Define spring behavior.
Note: Only one *SPRING card is output per component, therefore the spring elements in each component must have the same properties.
When the *SPRING card is written for SPRING1 elements, both dof1 and dof2 are written, but Abaqus only reads dof1.
For SPRINGA elements, choose the SPRINGA option in the *SPRING card image.
*SURFACE BEHAVIOR Define alternative pressure-overclosure relationships for contact.
*SURFACE INTERACTION Define surface interaction properties.
Note: For Abaqus Explicit template, this card is defined as a group.
*SURFACE PROPERTY / *EMISSIVITY Define surface properties for cavity radiation analysis. It must immediately precede the *EMISSIVITY option.
*SURFACE SECTION Specify section properties for surface elements.
*SURFACE SMOOTHING Create a surface smoothing definition for contact interactions. It must be used in conjunction with the *CONTACT PAIR option.
*TRANSVERSE SHEAR STIFFNESS Define transverse shear stiffness for beams and shells.
Note: This option must be used in conjunction with the *BEAM GENERAL SECTION, *BEAM SECTION, *COHESIVE SECTION, *SHELL GENERAL SECTION, or the *SHELL SECTION options. The transverse shear stiffness defined with this option affects only the transverse shear flexible elements whose section properties are defined by the immediately preceding section option.
ANSYS Cards
Card Description
SECTYPE Associates section type information with a section ID number.
LS-DYNA Cards
Card Description
*CONSTRAINED_JOINT_STIFFNESS_FLEXION-TORSION Define optional rotational and translational joint stiffness for joints.
*CONSTRAINED_JOINT_STIFFNESS_GENERALIZED Define optional rotational and translational joint stiffness for joints.
*CONSTRAINED_JOINT_STIFFNESS_TRANSLATIONAL Define optional rotational and translational joint stiffness for joints.
*DAMPING_PART_MASS Define mass weighted damping by part ID
*DAMPING_PART_MASS_SET
*DAMPING_PART_STIFFNESS Assign Rayleigh stiffness damping coefficient by part ID
*DAMPING_PART_STIFFNESS_SET
*DAMPING_RELATIVE Apply damping relative to the motion of a rigid body.
*DEFINE_CONNECTION_PROPERTIES Define failure related parameters for solid element spot weld failure by *MAT_SPOTWELD_DAIMLERCHRYSLER.
*EOS_GRUNEISEN (EOS 4) Equation of state Form 4.
*EOS_IDEAL_GAS (EOS 12) Equation of state for 12 for modeling ideal gas.
*EOS_IGNITION_AND_GROWTH_OF_REACTION_IN_HE (EOS 7) Equation of state Form 7.
*EOS_JWL (EOS 2) Equation of state Form 2.
*EOS_LINEAR_POLYNOMIAL (EOS 1) Equation of state Form 1. Define coefficients for linear polynomial EOS and initialize the initial thermodynamic state of the material.
*EOS_LINEAR_POLYNOMIAL_WITH_ENERGY_LEAK (EOS 6) Equation of state Form 6.
*EOS_PROPELLANT_DEFLAGRATION (EOS 10) Equation of state Form 10. Added to model airbag propellants.
*EOS_RATIO_OF_POLYNOMIALS (EOS 5) Equation of state Form 5.
*EOS_SACK_TUESDAY (EOS 3) Equation of state Form 3.
*EOS_TABULATED (EOS 9) Equation of state Form 9.
*EOS_TABULATED_COMPACTION (EOS 8) Equation of state Form 8.
*EOS_TENSOR_PORE_COLLAPSE (EOS 11) Equation of state Form 11.
*INTEGRATION_BEAM Define user defined through the thickness integration rules for the beam element.
*INTEGRATION_SHELL Define user defined through the thickness integration rules for the shell element.
*MAT_ADD_EROSION Many of the constitutive models in LS-DYNA do not allow failure and erosion. This option provides a way of including failure in these models although the option can also be applied to constitutive models of other failure/erosion criterion.
*SECTION_BEAM(TITLE) Define cross sectional properties for beam, truss, discrete beam and cable elements.
*SECTION_BEAM_AISC Defines cross-sectional properties for beams and trusses.
*SECTION_DISCRETE(TITLE) Define spring and damper elements for translation and rotation.
*SECTION_POINT_SOURCE(TITLE) Provides the inlet boundary condition for single gas flow (inflation potential) via a set of point source(s).
*SECTION_POINT_SOURCE_MIXTURE(TITLE) Provides: (a) an element formulation for a solid ALE part of the type similar to ELFORM=11 of *SECTION_SOLID and (b) the inlet gas injection boundary condition for multiple-gas mixture in-flow via a set of point sources.
*SECTION_SEATBELT(TITLE) Define section properties for the seat belt elements.
*SECTION_SHELL(TITLE) Define section properties for shell elements.
*SECTION_SHELL_ALE(TITLE) Define section properties for shell elements.
*SECTION_SHELL_EFG(TITLE) Define section properties for shell elements.
*SECTION_SOLID(TITLE) Define section properties for solid continuum and fluid elements.
*SECTION_SOLID_ALE(TITLE) Define section properties for solid continuum and fluid elements.
*SECTION_SOLID_EFG(TITLE) Define section properties for solid continuum and fluid elements.
*SECTION_SPH Define section properties for SPH particles.
*SECTION_SPH_TENSOR
*SECTION_SPH_USER
*SECTION_TSHELL(TITLE) Define section properties for SPH particles.
Nastran Cards
Only one card image can be loaded into each property collector.
1D elements can be grouped into components with 2D and 3D elements for display purposes. The component groupings are maintained on export and import.
Properties for PBAR and PBEAM cards can be manually input in the card image or automatically created.
The HM_ELAS card defines properties for an HM_Spring element.
The Nastran and OptiStruct solver interfaces allow the property between groups to have the same ID. For example, PBAR3, PSHELL 3 and PSOLID 3. Duplicate IDs within the same group is not allowed.
Nastran and OptiStruct properties are grouped as follows:
0D_Rigids
PMASS
1D
PBAR, PBARL, PBEAM, PBEAML, PBEAND, PROD, PTUBE, PWELD
SPRING_GAP
PBUSH, PBUSH1D, PDAMP, PELAS, PGAP, PVISC
2D
PSHELL, PSHEAR, PCOMP, PCOMG
3D
PSOLID
Card Description
BCBDPRP Defines contact body parameters.
BCONPRG Defines geometric contact parameters of touching bodies.
BCONPRP Defines physical contact parameters of touching bodies.
PAABSF Defines the properties of a frequency-dependent acoustic absorber element.
PACABS Defines the properties of the acoustic absorber element.
PACBAR Defines the properties of the acoustic barrier element.
Note: PACBAR is referenced by a CHACBR entry only.
Either FRESON or KRESON must be specified, but not both.
PACINF Defines the properties of acoustic conjugate infinite elements.
PAERO1 Defines associated bodies for the panels in the Doublet-Lattice method.
PAERO2 Defines the cross-sectional properties of aerodynamic bodies.
PAXSYMH Defines the properties of a linear axisymmetric harmonic element.
PBAR Defines the properties of a simple beam element (CBAR entry).
PBARL Defines the properties of a simple beam element (CBAR entry) by cross-sectional dimensions.
PBCOMP Alternate form of the PBEAM entry to define properties of a uniform cross-sectional beam referenced by a CBEAM entry.
PBEAM Defines the properties of a beam element (CBEAM entry). This element may be used to model tapered beams.
Note: Blank fields are not supported for intermediate stations. Appropriate default values are inserted during feinput.
PBEAML Defines the properties of a beam element by cross-sectional dimensions.
PBEND Defines the properties of a curved beam, curved pipe, or elbow element (CBEND entry).
PBUSH Defines the nominal property values for a generalized spring-and-damper structural element.
PBUSH1D Defines linear and nonlinear properties of a one-dimensional spring and damper element (CBUSH1D entry).
PBUSHT Defines the frequency dependent properties or the stress dependent properties for a generalized spring and damper structural element.
PCOMP Defines the properties of an n-ply composite material laminate.
PCOMPG Defines global (external) ply IDs and properties for a composite material laminate.
PCOMPLS Defines global (external) ply IDs and properties for a composite material laminate in SOL 600 and SOLs 400 and 700.
PCONVM Specifies forced convection boundary condition properties for a boundary condition surface element.
PDAMP Specifies the damping value of a scalar damper element using defined CDAMP1 or CDAMP3 entries.
PELAS Specifies the stiffness, damping coefficient, and stress coefficient of a scalar elastic (spring) element (CELAS1 or CELAS3 entry).
PELAST Defines the frequency dependent properties for a PELAS Bulk Data entry.
PFAST Defines the CFAST fastener property values.
PGAP Defines the properties of the gap element (CGAP entry).
PHBDY Property entry referenced by a CHBDYP element to give auxiliary geometric information for it.
PLPLANE
Defines the properties of a fully nonlinear (i.e., large strain and large rotation) hyperelastic plane strain
or axisymmetric element.
PLSOLID Defines a fully nonlinear (i.e., large strain and large rotation) hyperelastic solid element.
PMASS Specifies the mass value of a scalar mass element (CMASS1 or CMASS3 entries).
PROD Defines the properties of a rod element (CROD entry).
PSEAM Defines the PSEAM property values.
PSHEAR Defines the properties of a shear panel (CSHEAR entry).
PSHELL Defines the membrane, bending, transverse shear, and coupling properties of thin shell elements.
PSHELL1 Defines the properties of SOL 700 shell elements, which are more complicated than the shell elements defined using the PSHELL entry.
PSHLN1
PSOLID Defines the properties of solid elements (CHEXA, CPENTA, and CTETRA entries).
PTUBE Defines the properties of a thin-walled cylindrical tube element (CTUBE entry).
PVISC Defines properties of a one-dimensional viscous damping element (CVISC entry).
PWELD Defines the properties of connector (CWELD) elements.
OptiStruct Cards
Only one property definition is allowed on each property collector. For definitions like PMASS, which allow more than one definition on the same card, this is separated on import into four different cards.
1D elements can be organized into components with 2D and 3D elements, and these component groupings are maintained on export and import. However, this usage is not recommended.
Card Description
HM_ELAS Defines properties for a HM_Spring element.
Note: Bulk Data Entry
MODCHG The MODCHG command can be used to remove and/or reactivate contact interfaces and/or elements for this subcase. It is used only for nonlinear analysis.
Note: Subcase Information Entry
PAABSF Defines the properties of the fluid acoustic absorber element.
PACABS Defines the properties of an acoustic absorber element.
PACINF Defines the properties of Acoustic Infinite Elements.
PAXI Defines the properties of axisymmetric elements. Referenced by CTAXI entry.
Referenced by CTAXI.
PBAR Defines the properties of a simple beam (bar), which is used to create bar elements via the CBAR entry.
Exported in large field format by optistructlf template.
PBARL Defines the properties of a simple beam (bar) by cross-sectional dimensions, which is used to create bar elements via the CBAR entry.
PBEAM Defines the properties of beam elements defined via the CBEAM entry.
PBEAML Defines the properties of a beam element by cross-sectional dimensions that are used to create beam elements via the CBEAM entry.
PBUSH Defines the nominal property values for a generalized spring-damper-mass structural element.
PBUSH1D Defines the linear and nonlinear properties for a one-dimensional spring-and-damper structural element.
PCOMP Defines the structure and properties of an n-ply composite laminate material.
PCOMPG Defines the structure and properties of a composite laminate material, allowing for global ply identification.
PCOMPLS Defines global ply-based composite properties for layered solid shell composites.
PCOMPP Defines the properties of a composite laminate material used in ply-based composite definition.
PCONT Defines properties of a CONTACT interface.
PCONTX Defines properties of a CONTACT interface for geometric nonlinear analysis.
PDAMP Specifies the damping of a scalar damper element using defined CDAMP1 or CDAMP3 entry.
PELAS Used to define the stiffness and stress coefficient of a scalar elastic element (spring) by means of the CELAS1 or CELAS3 entry.
PFAST Define properties of connector (CFAST) elements.
PFATSMW Defines properties for seam weld fatigue analysis.
PFATSPW Defines properties for spot weld fatigue analysis.
PGAP Defines properties of the gap (CGAP or CGAPG) elements.
PGASK Defining the properties for solid gasket elements.
PJOINTG Defines the properties for a Joint connection between two grids via the JOINTG entry.
PLSOLID Defines the properties of nonlinear hyperelastic solid elements, referenced by CHEXA, CPENTA, and CTETRA Bulk Data Entries. The MATHE hyperelastic material can be referenced to define corresponding material properties.
PMASS Defines the mass value of a scalar mass element (CMASS1 or CMASS3 entry).
PROD Defines the properties of a rod, which is referenced by the CROD entry.
PSEAM Define properties of connector (CSEAM) elements.
PSHEAR Defines the properties of a shear panel.
PSHELL Defines the membrane, bending, transverse shear, and membrane-bending coupling of shell elements.
PSOLID Defines the properties of solid elements, referenced by CHEXA, CPENTA, CPYRA and CTETRA Bulk Data Entries.
PTUBE Defines the properties of a thin-walled cylindrical tube element, referenced by a CTUBE entry.
PWELD Defines properties of connector (CWELD) elements.
PAM-CRASH Cards
Card Description
CDATA /
CDATA block is a super user comment block of input file.
CHEM /
Chemical Reaction Definition, combustion model for FPM.
CNTPTY
Contact Properties Definition, Thermal Contact Conductance.
FRICT / Friction modeling definition.
FRICT / IFROPT = 1
Standard Coulomb Friction Model
FRICT / IFROPT = 2
Pressure-Dependent Friction by Curve
FRICT / IFROPT = 3
Velocity-Dependent Friction by Curve
FRICT / IFROPT = 4
Pressure- and Velocity-Dependent Friction by Curves
FRICT / IFROPT = 5
Pressure-Dependent Friction by Standard Function 1
FRICT / IFROPT = 6
Pressure-Dependent Friction by Standard Function 2
FRICT / IFROPT = 10
Orthotropic Friction
FRICT / IFROPT = 11
Orthotropic Friction with Arbitrary Orientation
FRICT / IFROPT = 12
User-Defined Friction Model
FRICT / IFROPT = 13
Lookup Table Dependent on Pressure, Velocity and Temperature
GASPEC / Specification of air bag gas.
LAYER / Ply identification and parameters
RUPMO / Rupture model definition.
NLAVE
Non-Local Average Option Definition, specifies a spatial averaging procedure for internal variables such as energy, stress and plastic strain
RUPMO / IRUPT = 0
Rupture Model Using Normal/Shear Load Criterion
RUPMO / IRUPT = 1
Rupture Model Using Stress Criterion
RUPMO / IRUPT = 2
Rupture Model Using a User-Defined Criterion for PLINKs
RUPMO / IRUPT = 3
Rupture Model Using a User-Defined Criterion for Spring-Beams
RUPMO / IRUPT = 5
RUPMO / IRUPT = 6
EWK Rupture Model (only for Material Types 16 and 117)
RUPMO / IRUPT = 7
Rupture Model Using Loads Criterion (Weighted Bending) for Material Types 223 and 224
RUPMO / IRUPT = 11
Rupture Models with User-Defined Criteria for Material Types 223, 224 and 302
RUPMO / IRUPT = 12
RUPMO / IRUPT = 13
Permas Cards
Card Description
CA1ZERF3 Zero Force Element with 1 Node and Three Translational Stiffnesses
CA2ZERF1 Translational Zero Force Element with 2 Nodes
CA2ZERF3 Zero Force Element with 2 Nodes and Three Translational Stiffnesses
$GEODAT BEAM Beam
$GEODAT CONA Surface convection
$GEODAT CONS Shell surface convection
$GEODAT DAMPER Viscous damper
$GEODAT FLANGE Flange
$GEODAT GASKET Gasket
$GEODAT MASS Mass
$GEODAT SCALAR Scalar
$GEODAT SHELL Shell
$GEODAT SOLID Solid
$GEODAT SPRING Spring
$GEODAT SPRINGX Spring
Radioss Cards
Radioss allows you to program your own properties, mostly for springs, that can be used in a simulation. Unsupported Radioss properties and user defined Radioss properties are assigned the PROP_UNSUPPORTED card image.
HyperMesh imports unsupported properties with the PROP_UNSUPPORTED card image, and preserves their corresponding IDs and associated components.
In the PROP_UNSUPPORTED card image, all property sub-options, parameters, and data lines are supported as simple text. HyperMesh does not check the validity or syntax of any data in this mode. You must manually check the validity of the data. No editing, updating, or review of the property data is intended. Also time step calculation and mass calculation are not available for the component that refers to this property.
Card Description
/ADMESH/SET Defines the criteria for adaptive meshing in parts. This keyword is not available for SPMD computation.
Note: Block Format Keyword
/DAMP/ Defines the Rayleigh mass and stiffness damping coefficients applied to a set of nodes. The damping can be applied to any nodal DOF either in local or global coordinate system.
/EOS/GRUNEISEN Describes the Gruneisen equation of state.
/EOS/POLYNOMIAL Describes the Linear polynomial equation of state P( ρ ,E).
/EOS/PUFF Describes the linear polynomial equation of state P(ρ,E) .
/EOS/SESAME Describes the SESAME table equation of state.
/EOS/TILLOTSON Describes the Tillotson equation of state.
/LEAK/MAT Specifies effective leakage area of porous airbag fabric materials LAW19 and LAW58 as function of time, pressure, area and other parameters.
/PROP Describes the property sets.
/PROP/TYPE3 (BEAM) Describes the beam property for torsion, bending, membrane or axial deformation.
/PROP/TYPE43 (CONNECT) Designed for spotweld, welding line or glue type connections. Only used with /MAT/CONNECT material law.
/PROP/TYPE14 (FLUID) Describes the general fluid property set.
/PROP/INJECT1 Describes mass injected for each constituent gas.
/PROP/INJECT2 Describes molar fraction injected for each constituent gas and total mass injected.
/PROP/TYPE18 (INT_BEAM) Describes the integrated beam property set. This beam model is based on Timoshenko theory and takes into account transverse shear strain without warping in torsion. It can be used for deep beam cases (short beams). Beam section and position of integration points can be either used as predefined or prescribed directly.
/PROP/TYPE33 (KJOINT) Describes the joint type spring.
/PROP/TYPE45 (KJOINT2) Describes the joint type spring between two rigid bodies.
/PROP/TYPE19 (PLY) Defines the ply property set used in ply-based composite definition. It is used in combination with /PROP/STACK (/PROP/TYPE17) or /PROP/TYPE51 to create ply-based sandwich composite properties.
/PROP/TYPE15 (POROUS) Describes the porous solid element property set (extended Darcy's law).
/PROP/TYPE5 (RIVET) Describes the rivet property set.
/PROP/TYPE10 (SH_COMP) Defines the composite shell property set. It is possible to define composite with several layers and each layer with individual orthotropic direction.
/PROP/TYPE16 (SH_FABR) Defines the anisotropic layered shell property set. This property is currently only compatible with Elastic Anisotropic Fabric (/MAT/LAW58 (FABR_A)) and only one layer is allowed.
/PROP/TYPE9 (SH_ORTH) Defines the orthotropic shell property.
/PROP/TYPE11 (SH_SANDW) Defines the sandwich shell property set. It is possible to define sandwich composite with several layers and each lay with individual material, thickness, layer position and orthotropic direction. This property is only compatible with Material Laws 15, 25, 27, 36, 60, 72 and user laws.
/PROP/TYPE1 (SHELL) Describes the shell property set which used for 3-node or 4-node shell element. Belytschko, QBAT or QEPH shell formulation are available.
/PROP/TYPE6 (SOL_ORTH) Describes the orthotropic solid property set. This property set is used to define the fiber plane for /MAT/LAW14(COMPS0), the steel reinforcement direction for /MAT/LAW24 (CONC) or the cell direction for /MAT/LAW28 (HONEYCOMB). This property is only available for 8-node linear solid elements (/BRICK), tetrahedron elements (/TETRA4 and /TETRA10), and 2D solid elements (/QUAD). Quadratic bricks (/BRIC20 and /SHEL16) and pentahedron elements (/PENTA6) are not compatible with this property.
/PROP/TYPE14 (SOLID) Defines the general solid property set.
/PROP/SPH Defines the axisymmetric spring property set.
/PROP/TYPE25 (SPR_AXI) Defines the axisymmetric spring property set.
/PROP/TYPE13 (SPR_BEAM) A beam type spring property that works as a beam element with six independent modes of deformation. This spring accounts for non-linear stiffness, damping and different unloading. Deformation, force and energy-based failure criteria are available.
/PROP/TYPE44 (SPR_CRUS) A spring element property that represents a simple macro model of a crushable frame in compression, tension, torsion and bending. Originally, this element was developed in cooperation with PSA PEUGEOT CITROËN.
/PROP/TYPE8 (SPR_GENE) A spring property that works with six independent modes of deformation. This spring accounts for non-linear stiffness, damping and different unloading. Deformation, force and energy based failure criteria are available. The general spring property is often used to model a joint connection between two parts.
/PROP/TYPE32 (SPR_PRE) Describes the pretension spring property set.
/PROP/TYPE12 (SPR_PUL) A pulley spring property set (with one translational DOF) used to model a pulley.
/PROP/TYPE26 (SPR_TAB) Defines the tabulated spring property.
/PROP/TYPE4 (SPRING) Defines spring property with one translational DOF. This spring accounts for non-linear stiffness, damping and different unloading. Deformation based failure criteria is available.
/PROP/TYPE17 (STACK) Defines the sandwich shell property set using the stack and ply approach.
/PROP/TYPE2 (TRUSS) Defines the truss property set.
/PROP/TYPE22 (TSH_COMP) Defines the composite thick shell property set.
/PROP/TYPE21 (TSH_ORTH) Defines the orthotropic thick shell property set.
/PROP/TYPE20 (TSHELL) Defines the general thick shell property set.
/PROP/USER User-defined property.
/PROP/TYPE0 (VOID) Defines the void property set.
/THERM_STRESS/MAT Adds thermal expansion property for Radioss material (shell and solid).
Samcef Cards
Card Description
.BPR Define beam profiles.
.ETASHELL Used to assign the laminate to the elements. The Projection method is supported.
.ETASOLID Used to assign the laminate to the elements. The Projection method is supported.
.MCCBUSH Defines the property on the BUSH element.
.PHP SHELL Assign physical properties to an existing mesh.
SOLIDMAT Assign physical properties to an existing mesh.
Note: This is a dummy property that creates a link between the elements and the material, as it is not possible to directly assign a material to the elements.
