Collectors are named organizational containers for collected entities. Collected entities are nameless entities which must
reside within one, and only one, collector. Collected entities are mutually exclusive to a collector.
Morph constraint entities restrict the movements of nodes or force compliance with dimensional requirements during morphing.
These constraints are always valid for all available morphing approaches.
Morph volume entities are highly deformable six-sided prisms which surround a portion of the FE mesh, and can be used
to manipulate a mesh by manipulating the shape of the morph volume.
Rapidly change the shape of the FE mesh without severely sacrificing the mesh quality and create, edit, and apply
shapes for subsequent design optimization studies.
The Design Space environment is dedicated to topology optimization model build and setup. It facilitates rapid model creation by generating
the voxel design space for a number of different use cases.
Many essential utility tools using HyperWorks-Tcl have been developed over the years to support Aerospace customers. A few tools have been collected and upgraded to
be compatible with this release.
Domains
Domain entities divide the model into different domains during morphing.
Handles
Handle entities control the shape of domains during morphing.
Morph Constraints
Morph constraint entities restrict the movements of nodes or force compliance with dimensional requirements during morphing. These constraints are always valid for all available morphing approaches.
Morph Volumes
Morph volume entities are highly deformable six-sided prisms which surround a portion of the FE mesh, and can be used to manipulate a mesh by manipulating the shape of the morph volume.
Shapes
Shape entities are collections of handle and/or node perturbations from the initial configuration of the FE mesh before morphing.
Symmetries
Symmetry entities define planes of symmetry within a model so that morphs can be applied in a symmetric fashion.
