Report Parameters
Multiple report parameters are supported in HyperView.
Global (Model)
  • Model Title (Hvmodel Title)
  • Loadcase ID (Hvmodel Loadcaseid)
  • Simulation index (Hvmodel Simulationindex)
  • MeshMode (Hvmodel Meshmode)
  • PolygonMode (Hvmodel Polygonmode)
Contour
  • Data type (Hvcontourctrl Datatype)
  • Data comp (Hvcontourctrl Datacomp)
  • Legend position (Hvcontourctrl Legendposition)
  • Legend header text (Hvlegendheader Text)
  • Legend header font name (Hvlegendheader Fontname)
  • Legend header font size (Hvlegendheader Fontsize)
  • Legend footer text (Hvlegendfooter Text)
  • Legend footer font name (Hvlegendfooter Fontname)
  • Legend footer font size (Hvlegendfooter Fontsize)
Tensor
Vector
Deformed
  • Deformed scale mode (Hvscalectrl Scalemode)
  • Deformed scale factor (Hvscalectrl Scalefactor)
  • Deformed data type (Hvscalectrl Datatype)
  • Undeformed mode (Hvscalectrl Undeformedmode)
  • Undeformed color (Hvscalectrl Undeformedcolor)
Tracing
  • Tracing mode (Hvtracingctrl Tracingmode)
  • Tracing steps (Hvtracingctrl Tracingsteps)
  • Tracing line width (Hvtracingctrl Linewidth)
  • Tracing line color (Hvtracingctrl Linecolor)
Section Cut
  • Section cut base coords-x (Hvsection Basecorrdsx)
  • Section cut base coords-y (Hvsection Basecorrdsy)
  • Section cut base coords-z (Hvsection Basecorrdsz)
  • Section cut color (Hvsection Color)
  • Section cut cross-section width (Hvsection Crosssectionwidth)
  • Section cut label (Hvsection Label)
  • Section cut visibility (Hvsection Visibility)
Measure
  • Measure color (Hvmeasure Color)
  • Measure font name (Hvmeasure Fontname)
  • Measure font size (Hvmeasure Fontsize)
  • Measure font slant (Hvmeasure Fontslant)
  • Measure font weight (Hvmeasure Fontweight)
  • Measure label (Hvmeasure Label)
  • Measure visibility (Hvmeasure Visibility)
  • Measure entities (Node/Element/Part/System)
  • Measure locator1 (Hvmeasurelocator1 Locator1)
  • Measure locator2 (Hvmeasurelocator1 Locator2)
  • Measure locator3 (Hvmeasurelocator1 Locator3)
Note: The number of locators listed is dependent upon the measure type that is selected (for example, "Position" only provides one locator while "Distance Between" provides two locators).
Notes
  • Note transparency (Hvnote Transparency)
  • Note x coordinates (Hvnote Xcoordinates)
  • Note y coordinates (Hvnote Ycoordinates)
  • Note z coordinate (Hvnote Zcoordinates)
  • Note x position (Hvnote Xposition)
  • Note y position (Hvnote Yposition)
  • Note border width (Hvnote Borderwidth)
  • Note horizontal alignment (Hvnote Horizontalalignment)
  • Note anchor to screen (Hvnote Anchortoscreen)
  • Note auto hide (Hvnote Autohide)
  • Note text (Hvnote Text)
  • Note color (Hvnote Color)
  • Note fill color (Hvnote Fillcolor)
  • Note label (Hvnote Label)
  • Note visibility (Hvnote Visibility)
  • Note locator (Hvnote Locator)
  • Note font name (Hvnote Fontname)
  • Note font size (Hvnote Fontsize)
  • Note font slant (Hvnote Fontslant)
  • Note font weight (Hvnote Fontweight)
  • Note entities (Node/Element/Part/System)
View - CurrentView
  • Fit (Hvview Fit)
  • Standard View (Hvview Standardview)
Tracking
  • Tracking entity (Hvtrackingctrl Entity)
  • Tracking label (Hvtrackingctrl Label)
  • Tracking entities (Node/Element/Part/System)
  • Tracking locator1 (Hvtrackingctrllocator1 Locator1)
  • Tracking locator2 (Hvtrackingctrllocator1 Locator2)
  • Tracking locator3 (Hvtrackingctrllocator1 Locator3)
Note: The number of locators listed is dependent upon the tracking system that is selected (for example, "Node" only provides one locator while "Plane" provides three locators).
