Feed-forward Steering Controller - Two-wheelers
This controller is used in case of simulating two-wheelers to follow a demand path profile provided by the user.
The controller employs a cascaded Feedforward and feedback algorithm to follow the specified path using steering angle as the control variable. For more details on the algorithm, please look at the Path following control for two-wheelers section.
The controller block for this controller can be specified as:
[FF_STEER_CONTROLLER]
TAG = 'FEEDFORWARD'
LOOK_AHEAD_TIME = 0.1
PATH = 'PREDEFINED'
BLOCK = 'PATH'
LEAN_CONTROL = 'PID_CONTROLLER'
LAT_KP = 0.03
LAT_KI = 0
LAT_KD = 0
[PID_CONTROLLER]
TAG = 'PID'
TYPE = 'FOLLOW_LEAN'
KP = 60
KI = 80
KD = 20
[PATH]
TYPE = 'CONSTANT_RADIUS'
RADIUS = 40000
INITIAL_STRAIGHT = 20000
TURN = 'LEFT'
In the above example, the path following Feedforward controller is specified using the ‘FEEDFORWARD’ tag and providing the required parameters. The demand path is specified in ‘PATH’ which is a constant radius path of radius 40 m with initial straight section of 20 m. The demand path can be specified in other ways as mentioned in the Demand Path for Steering Controllers section.
TAG Attr - string REQUIRED
<FEEDFORWARD >
LOOK_AHEAD_TIME Attr - string REQUIRED
Specifies look ahead time for the controller used to predict the curvature of the path ahead.
LEAN_CONTROL Attr - string REQUIRED
Block name for the LEAN_CONTROL block where the parameters for the lean follower controller are defined.
LAT_KP Attr - real OPTIONAL
Proportional constant for the PID controller used to eliminate predicted lateral error after look ahead time.
If absent, the default value of 0.03 is assumed.
LAT_KI Attr - real OPTIONAL
Integral constant for the PID controller used to eliminate predicted lateral error after look ahead time.
If absent, the default value of 0 is assumed.
LAT_KD Attr - real OPTIONAL
Derivative constant for the PID controller used to eliminate predicted lateral error after look ahead time.
Note:
  • The behavior of the controller following a demand lean depends on the values for KP, KI, and KD.
  • If the behavior is not acceptable for a vehicle, the constants need to be tuned.
