Run Edited .fem files in the Flexbody Prep Wizard
  1. Open MotionView.
  2. From the FlexTools menu, select Flex Prep.
  3. Select the FEA to H3D option.
  4. Select the Bulk Data file (.fem) that was output from OptiStruct.
  5. Select the three edited .fem files.
  6. Specify the name for the .h3d file. Give the file the same name as the original filename, but with the suffix .flex.
  7. Choose the same interface nodes and modal information as specified earlier.
  8. Choose the correct units.
  9. Click Finish.
