Find Dialog
  1. Right-click anywhere in the browser.
  2. Select Find from the pop-up context menu (located at the bottom of the list).
    Note: The CTRL + F keyboard shortcut can also be used.
    The find dialog is displayed:
  3. Key in a search string in the field and press Enter on the keyboard or click on Next.
  4. Use the Options drop-down menu to select which columns to include in the search, or to ignore the case sensitivity.
  5. Click the Prev button to go to the previously found entity.
  6. Click Close to close the dialog.
