Delete a Note
  1. Select a note from the note list or click a note box from the active window.
  2. Click Cut.
    The note is removed from the window and from the list.
    Note: Any note can be deleted, except for the MediaInfo note.
    Note: When a video image file is either cut or copied, notes attached to the file are also cut or copied.
