Rapidly change the shape of the FE mesh without severely sacrificing the mesh quality and create, edit, and apply
shapes for subsequent design optimization studies.
The Design Space environment is dedicated to topology optimization model build and setup. It facilitates rapid model creation by generating
the voxel design space for a number of different use cases.
Many essential utility tools using HyperWorks-Tcl have been developed over the years to support Aerospace customers. A few tools have been collected and upgraded to
be compatible with this release.
From the Define
panel, select a curve from the Curve list or pick a curve from the active
window.
Click Cut from the curve list controls.
The selected curve is removed from the list and is no longer displayed
in the active window. The cut curve can be pasted in any HyperGraph or 3D window.
