Use Values as a Data Source
  1. From the Bar Chart Define panel, select Source > Values.
  2. Enter a value in the Curve column of the Values table. You can enter a value for each available bar chart category.
    You can also plot category values using a Templex function. For example, {p1w1.category}.
  3. Click Apply.
