Root Cause Analysis
From risk detection to problem solving, the diagnosis and root cause identification is a necessary step. SnRD Post-Processing proposes two modules:
  1. Modal Contribution
    The E-Line method is a time domain analysis approach, using Modal Transient Analysis, also known as the Modal Superposition Method. This enables a transition to the frequency domain.
    Where:
    • U(t) is the time domain displacement
    • N is the number of modes extracted
    • mi is the Modal displacement for a mode i
    • ѱi is the Participation factor for mode i
    With all the above responses available in the standard outputs from OptiStruct Analysis, the Relative Modal Contribution [%] values can be calculated. These will describe the participation of a mode or modes on a peak of the time domain response.
  2. Modal Sensitivity
    The modal sensitivity allows the analyst to live perform what-if studies by altering the time domain response of an E-Point or complete E-Line. This is achieved by decomposition of the Modal Superposition response, applying a factor (between 0 and 1) on selected modes, damping, canceling or isolating them.
    Figure 3.
