Unit Systems
Provides data about the units used in the model from solver cards “UNITS” and “DTI_UNITS”. Other commonly used unit systems are available by default.
- Right-click at the Report or Chapter level and select .
- Below are the properties associated with the Unit Systems module. Figure 1.
- Name: Provide the name for the Unit System module.
Basic Options
- Unit System: Select the unit system being used for the analysis.
Note: Commonly used units are already listed. If Solver is selected, units in Solver are also available.
Advanced options
- Auto Split Table: Provides the function to split up tables automatically based on the space available in the slide or page.
Once executed, a table output for Unit System is generated:
