Slides of Existing Slides
Add existing slides from the master Presentation to the report.
- Right-click at the report level and select
The selected slide is added to the tree. If any report item is present in the slide, the associated placeholders and respective properties are listed in the property area.
. - If a Presentation master is imported and does not contain existing slides,
the menu lists No slides found.Figure 1.
