Subtraction assignment operator.
var_name -= sca_expr
Operands
var_name
A scalar variable.
sca_expr
A valid scalar expression.
Expression Result
a -= a , where a = 2 0
a -= 3 , where a = 2 -1
The subtraction assignment operator decreases the value of var_name by sca_expr. This operator is typically used in loop constructs.
The subtraction assignment operator is not valid when used with curve-editing functions.
