ardi::item::exceldocument
Interact with items of type exceldocument.
Supported property names are: -name -value -parent -type (read only) -file -sheet -caption -caption_location All properties available can be passed via the "create" API or modified on an existing item via the "set" API.
ardi::item::exceldocument create args
Creates an item of type "exceldocument".
For a full list of property names, see above.
Returns
The ID of the item or tcl-error in case an error occurred during creation. i.e ardi::api::item::exceldocument create -name "My External Excel Document Item"
ardi::item::exceldocument delete args
Deletes the item with the specified ID.
-id (mandatory)
value: item ID. The item ID which is returned by the corresponding "create" API.
default value: ""
Returns
1 for ok
tcl-error in case of error i.e ardi::api::item::exceldocument delete -id $id
ardi::item::exceldocument get args
Queries the value of one property.
-id (mandatory)
default value: ""
Returns
ardi::item::exceldocument getcell args
Queries the value of one property from a table cell.
-id (mandatory)
default value: ""
-row (mandatory)
value: row ID. Row ID is an integer starting from 0.
-column (mandatory)
value: column ID. Column ID is an integer starting from 0.
-property (mandatory)
value: property name. 'value' or 'href'.
Returns
The value of the specified property or tcl-error in case of error usage: ardi::item::exceldocument getcell -id $id -row 0 -column 0 -property value
Note: Available only when a Word report is exported without using platform-independent export.
ardi::item::exceldocument getpropertyid args
Queries id of property.
-id
value: item ID
-key
value: property key
ardi::item::exceldocument getpropertykeylist args
Queries list of properties.
-id
value: item ID
Returns
list of property keys for a particular item ID
ardi::item::exceldocument set args
Sets one or multiple parameters to specified values. The type of the item is assigned upon creation and cannot be changed after.
-id (mandatory)
default value: ""
Returns
ardi::item::exceldocument setcell args
Sets one or multiple parameters to a table cell.
-id (mandatory)
default value: ""
-row (mandatory)
-column (mandatory)
-value
value: The value you want to set on the cell.
-href
value: Object ID to hyperlink.
Returns
1 for ok, tcl-error in case of error I.e ardi::api::item::exceldocument setcell -id $id -row 0 -column 0 -value "Hello" -href $refobjid.
