Examples
Static Analysis
Transient Analysis
Complex Results
Figure 3.
Element Results with Layers and ID Pool
Figure 4.
2D Tensor Result with Corner Data
Figure 5.
Results in Element System
Figure 6.
Delimiter and Animation Source
Figure 7.
Include File
Figure 8.
HWASCII File
ALTAIR ASCII FILE
$SUBCASE = 1 "SUBCASE 1 = ls "
$BINDING = NODE
$COLUMN_INFO = ENTITY_ID
$RESULT_TYPE = Displacement(v)
1         2.675570E-04   -1.055090E-04  0.000000E+00
2         2.507720E-04   -9.883090E-05  0.000000E+00
3         2.440140E-04   -8.849120E-05  0.000000E+00
4         2.400880E-04   -7.778800E-05  0.000000E+00
5         2.382920E-04   -6.713340E-05  0.000000E+00
6         2.381860E-04   -5.667990E-05  0.000000E+00
7         2.399790E-04   -4.656910E-05  0.000000E+00
8         2.440990E-04   -3.715890E-05  0.000000E+00
9         2.569460E-04   -3.123160E-05  0.000000E+00
10        2.378820E-04   -9.724510E-05  0.000000E+00
11        2.261050E-04   -8.938470E-05  0.000000E+00
12        2.183770E-04   -8.228280E-05  0.000000E+00
13        2.144560E-04   -7.396890E-05  0.000000E+00
14        2.126330E-04   -6.531210E-05  0.000000E+00
15        2.126250E-04   -5.672990E-05  0.000000E+00
16        2.144460E-04   -4.859660E-05  0.000000E+00
17        2.194190E-04   -4.158990E-05  0.000000E+00
18        2.270470E-04   -3.354960E-05  0.000000E+00
19        2.065580E-04   -9.435890E-05  0.000000E+00
20        1.993960E-04   -8.558060E-05  0.000000E+00
21        1.931290E-04   -7.805470E-05  0.000000E+00
22        1.891980E-04   -7.077870E-05  0.000000E+00
23        1.874210E-04   -6.327090E-05  0.000000E+00
24        1.873940E-04   -5.576850E-05  0.000000E+00
25        1.892170E-04   -4.847780E-05  0.000000E+00
26        1.927070E-04   -4.088540E-05  0.000000E+00
27        1.963510E-04   -3.220370E-05  0.000000E+00
28        1.759030E-04   -9.295610E-05  0.000000E+00
29        1.714210E-04   -8.391900E-05  0.000000E+00
30        1.669840E-04   -7.588670E-05  0.000000E+00
31        1.637570E-04   -6.845360E-05  0.000000E+00
32        1.621190E-04   -6.121470E-05  0.000000E+00
33        1.620260E-04   -5.397270E-05  0.000000E+00
34        1.632340E-04   -4.653920E-05  0.000000E+00
35        1.651600E-04   -3.857390E-05  0.000000E+00
36        1.665810E-04   -2.973420E-05  0.000000E+00
37        1.458880E-04   -9.218070E-05  0.000000E+00
38        1.430520E-04   -8.302430E-05  0.000000E+00
39        1.400460E-04   -7.461920E-05  0.000000E+00
40        1.376770E-04   -6.679290E-05  0.000000E+00
41        1.363570E-04   -5.926470E-05  0.000000E+00
42        1.361240E-04   -5.175800E-05  0.000000E+00
43        1.367060E-04   -4.401210E-05  0.000000E+00
44        1.375140E-04   -3.578490E-05  0.000000E+00
45        1.376660E-04   -2.693740E-05  0.000000E+00
46        1.163350E-04   -9.165220E-05  0.000000E+00
47        1.145410E-04   -8.242320E-05  0.000000E+00
48        1.125730E-04   -7.372090E-05  0.000000E+00
49        1.109470E-04   -6.547520E-05  0.000000E+00
50        1.099700E-04   -5.749100E-05  0.000000E+00
51        1.096870E-04   -4.954260E-05  0.000000E+00
52        1.098490E-04   -4.143300E-05  0.000000E+00
53        1.099740E-04   -3.298910E-05  0.000000E+00
54        1.094280E-04   -2.416260E-05  0.000000E+00
55        8.707490E-05   -9.123270E-05  0.000000E+00
56        8.596180E-05   -8.194280E-05  0.000000E+00
57        8.472750E-05   -7.300680E-05  0.000000E+00
58        8.367890E-05   -6.438790E-05  0.000000E+00
59        8.301700E-05   -5.595380E-05  0.000000E+00
60        8.277160E-05   -4.753820E-05  0.000000E+00
61        8.277980E-05   -3.901260E-05  0.000000E+00
62        8.259080E-05   -3.037550E-05  0.000000E+00
63        8.172000E-05   -2.153050E-05  0.000000E+00
64        5.798220E-05   -9.089970E-05  0.000000E+00
65        5.733730E-05   -8.155900E-05  0.000000E+00
66        5.662390E-05   -7.244890E-05  0.000000E+00
67        5.600950E-05   -6.354170E-05  0.000000E+00
68        5.561270E-05   -5.473560E-05  0.000000E+00
69        5.545660E-05   -4.589810E-05  0.000000E+00
70        5.544530E-05   -3.692350E-05  0.000000E+00
71        5.538980E-05   -2.783880E-05  0.000000E+00
72        5.446080E-05   -1.907040E-05  0.000000E+00
73        2.897410E-05   -9.067840E-05  0.000000E+00
74        2.867840E-05   -8.130300E-05  0.000000E+00
75        2.835350E-05   -7.208490E-05  0.000000E+00
76        2.807260E-05   -6.299480E-05  0.000000E+00
77        2.789020E-05   -5.394220E-05  0.000000E+00
78        2.782200E-05   -4.479850E-05  0.000000E+00
79        2.783480E-05   -3.543620E-05  0.000000E+00
80        2.784510E-05   -2.573960E-05  0.000000E+00
81        2.789890E-05   -1.584560E-05  0.000000E+00
82        2.903350E-04   -1.291340E-04  0.000000E+00
83        2.781780E-04   -1.101870E-04  0.000000E+00
84        2.705260E-04   -9.483520E-05  0.000000E+00
85        2.665760E-04   -8.126120E-05  0.000000E+00
86        2.646720E-04   -6.848620E-05  0.000000E+00
87        2.645070E-04   -5.604280E-05  0.000000E+00
88        2.661590E-04   -4.349700E-05  0.000000E+00
89        2.710040E-04   -3.002200E-05  0.000000E+00
90        2.793670E-04   -1.444070E-05  0.000000E+00
91        0.000000E+00   -9.059880E-05  0.000000E+00
92        0.000000E+00   -8.121120E-05  0.000000E+00
93        0.000000E+00   -7.195480E-05  0.000000E+00
94        0.000000E+00   -6.279930E-05  0.000000E+00
95        0.000000E+00   -5.365590E-05  0.000000E+00
96        0.000000E+00   -4.439450E-05  0.000000E+00
97        0.000000E+00   -3.485870E-05  0.000000E+00
98        0.000000E+00   -2.488340E-05  0.000000E+00
99        0.000000E+00   -1.390980E-05  0.000000E+00
100       3.489630E-04   -1.501470E-04  0.000000E+00
101       3.287750E-04   0.000000E+00   0.000000E+00
102       2.898680E-04   -1.155390E-04  0.000000E+00
103       2.721430E-04   -2.067990E-05  0.000000E+00
104       2.471570E-04   -1.081430E-04  0.000000E+00
105       2.315090E-04   -2.305800E-05  0.000000E+00
106       2.114200E-04   -1.047150E-04  0.000000E+00
107       1.972640E-04   -2.214240E-05  0.000000E+00
108       1.786880E-04   -1.029570E-04  0.000000E+00
109       1.658830E-04   -2.010520E-05  0.000000E+00
110       1.475890E-04   -1.019460E-04  0.000000E+00
111       1.362260E-04   -1.761070E-05  0.000000E+00
112       1.174250E-04   -1.012740E-04  0.000000E+00
113       1.076760E-04   -1.505010E-05  0.000000E+00
114       8.778540E-05   -1.007790E-04  0.000000E+00
115       7.984900E-05   -1.258870E-05  0.000000E+00
116       5.842140E-05   -1.004110E-04  0.000000E+00
117       5.245600E-05   -1.009330E-05  0.000000E+00
118       2.918660E-05   -1.001770E-04  0.000000E+00
119       2.542870E-05   -7.723280E-06  0.000000E+00
120       0.000000E+00   -1.000940E-04  0.000000E+00
121       0.000000E+00   0.000000E+00   0.000000E+00
$BINDING = NODE
$RESULT_TYPE = Rotation(v)
1         0.000000E+00   0.000000E+00   -1.806490E-05
2         0.000000E+00   0.000000E+00   -1.170600E-05
3         0.000000E+00   0.000000E+00   -5.260080E-06
4         0.000000E+00   0.000000E+00   -3.344090E-06
5         0.000000E+00   0.000000E+00   -1.252660E-06
6         0.000000E+00   0.000000E+00   7.145260E-07
7         0.000000E+00   0.000000E+00   2.250660E-06
8         0.000000E+00   0.000000E+00   7.860970E-06
9         0.000000E+00   0.000000E+00   1.204470E-05
10        0.000000E+00   0.000000E+00   -7.530430E-06
11        0.000000E+00   0.000000E+00   -8.588370E-06
12        0.000000E+00   0.000000E+00   -5.613000E-06
13        0.000000E+00   0.000000E+00   -3.121340E-06
14        0.000000E+00   0.000000E+00   -1.426400E-06
15        0.000000E+00   0.000000E+00   1.507800E-07
16        0.000000E+00   0.000000E+00   2.283040E-06
17        0.000000E+00   0.000000E+00   4.403640E-06
18        0.000000E+00   0.000000E+00   2.618820E-06
19        0.000000E+00   0.000000E+00   -3.909920E-06
20        0.000000E+00   0.000000E+00   -4.629730E-06
21        0.000000E+00   0.000000E+00   -4.226740E-06
22        0.000000E+00   0.000000E+00   -2.810640E-06
23        0.000000E+00   0.000000E+00   -1.475940E-06
24        0.000000E+00   0.000000E+00   -2.306630E-07
25        0.000000E+00   0.000000E+00   8.773280E-07
26        0.000000E+00   0.000000E+00   9.186020E-07
27        0.000000E+00   0.000000E+00   1.134890E-07
28        0.000000E+00   0.000000E+00   -2.303240E-06
29        0.000000E+00   0.000000E+00   -2.891730E-06
30        0.000000E+00   0.000000E+00   -2.750930E-06
31        0.000000E+00   0.000000E+00   -2.229480E-06
32        0.000000E+00   0.000000E+00   -1.433090E-06
33        0.000000E+00   0.000000E+00   -7.086170E-07
34        0.000000E+00   0.000000E+00   -3.585900E-07
35        0.000000E+00   0.000000E+00   -3.970740E-07
36        0.000000E+00   0.000000E+00   -1.228800E-06
37        0.000000E+00   0.000000E+00   -1.418680E-06
38        0.000000E+00   0.000000E+00   -1.845080E-06
39        0.000000E+00   0.000000E+00   -1.892540E-06
40        0.000000E+00   0.000000E+00   -1.662370E-06
41        0.000000E+00   0.000000E+00   -1.319160E-06
42        0.000000E+00   0.000000E+00   -1.023910E-06
43        0.000000E+00   0.000000E+00   -9.154510E-07
44        0.000000E+00   0.000000E+00   -1.152990E-06
45        0.000000E+00   0.000000E+00   -1.751130E-06
46        0.000000E+00   0.000000E+00   -9.378330E-07
47        0.000000E+00   0.000000E+00   -1.219860E-06
48        0.000000E+00   0.000000E+00   -1.305140E-06
49        0.000000E+00   0.000000E+00   -1.254600E-06
50        0.000000E+00   0.000000E+00   -1.141180E-06
51        0.000000E+00   0.000000E+00   -1.083060E-06
52        0.000000E+00   0.000000E+00   -1.178980E-06
53        0.000000E+00   0.000000E+00   -1.428740E-06
54        0.000000E+00   0.000000E+00   -1.984710E-06
55        0.000000E+00   0.000000E+00   -6.337950E-07
56        0.000000E+00   0.000000E+00   -8.086770E-07
57        0.000000E+00   0.000000E+00   -8.928530E-07
58        0.000000E+00   0.000000E+00   -9.127060E-07
59        0.000000E+00   0.000000E+00   -9.178150E-07
60        0.000000E+00   0.000000E+00   -9.618740E-07
61        0.000000E+00   0.000000E+00   -1.174630E-06
62        0.000000E+00   0.000000E+00   -1.574790E-06
63        0.000000E+00   0.000000E+00   -1.888970E-06
64        0.000000E+00   0.000000E+00   -4.055300E-07
65        0.000000E+00   0.000000E+00   -5.030470E-07
66        0.000000E+00   0.000000E+00   -5.655450E-07
67        0.000000E+00   0.000000E+00   -6.043770E-07
68        0.000000E+00   0.000000E+00   -6.405200E-07
69        0.000000E+00   0.000000E+00   -7.382430E-07
70        0.000000E+00   0.000000E+00   -8.778130E-07
71        0.000000E+00   0.000000E+00   -1.433290E-06
72        0.000000E+00   0.000000E+00   -2.348860E-06
73        0.000000E+00   0.000000E+00   -1.993380E-07
74        0.000000E+00   0.000000E+00   -2.423400E-07
75        0.000000E+00   0.000000E+00   -2.734500E-07
76        0.000000E+00   0.000000E+00   -2.952910E-07
77        0.000000E+00   0.000000E+00   -3.240560E-07
78        0.000000E+00   0.000000E+00   -3.615310E-07
79        0.000000E+00   0.000000E+00   -5.285360E-07
80        0.000000E+00   0.000000E+00   -5.365600E-07
81        0.000000E+00   0.000000E+00   -1.916910E-06
82        0.000000E+00   0.000000E+00   -3.102620E-05
83        0.000000E+00   0.000000E+00   -8.088780E-06
84        0.000000E+00   0.000000E+00   -6.554530E-06
85        0.000000E+00   0.000000E+00   -2.967490E-06
86        0.000000E+00   0.000000E+00   -1.165990E-06
87        0.000000E+00   0.000000E+00   5.222050E-07
88        0.000000E+00   0.000000E+00   3.686480E-06
89        0.000000E+00   0.000000E+00   4.565990E-06
90        0.000000E+00   0.000000E+00   2.465290E-05
91        0.000000E+00   0.000000E+00   -1.515880E-08
92        0.000000E+00   0.000000E+00   -1.430560E-08
93        0.000000E+00   0.000000E+00   -3.032030E-08
94        0.000000E+00   0.000000E+00   -6.294120E-08
95        0.000000E+00   0.000000E+00   -1.051740E-07
96        0.000000E+00   0.000000E+00   -1.718360E-07
97        0.000000E+00   0.000000E+00   -2.087570E-07
98        0.000000E+00   0.000000E+00   -4.611200E-07
99        0.000000E+00   0.000000E+00   -4.233090E-07
100       0.000000E+00   0.000000E+00   -5.650720E-05
101       0.000000E+00   0.000000E+00   4.300920E-05
102       0.000000E+00   0.000000E+00   -2.013980E-05
103       0.000000E+00   0.000000E+00   1.154850E-05
104       0.000000E+00   0.000000E+00   -6.182510E-06
105       0.000000E+00   0.000000E+00   1.919990E-06
106       0.000000E+00   0.000000E+00   -3.624680E-06
107       0.000000E+00   0.000000E+00   -4.986140E-07
108       0.000000E+00   0.000000E+00   -1.931390E-06
109       0.000000E+00   0.000000E+00   -1.609830E-06
110       0.000000E+00   0.000000E+00   -1.202140E-06
111       0.000000E+00   0.000000E+00   -2.086890E-06
112       0.000000E+00   0.000000E+00   -7.945170E-07
113       0.000000E+00   0.000000E+00   -2.158870E-06
114       0.000000E+00   0.000000E+00   -5.501360E-07
115       0.000000E+00   0.000000E+00   -2.318380E-06
116       0.000000E+00   0.000000E+00   -3.609470E-07
117       0.000000E+00   0.000000E+00   -1.880750E-06
118       0.000000E+00   0.000000E+00   -1.794450E-07
119       0.000000E+00   0.000000E+00   -4.222610E-06
120       0.000000E+00   0.000000E+00   -2.133690E-08
121       0.000000E+00   0.000000E+00   -4.595710E-06
$BINDING = ELEMENT
$RESULT_TYPE = Total Ply Thickness(s)
1         8.000000E+00
2         8.000000E+00
3         8.000000E+00
4         8.000000E+00
5         8.000000E+00
6         8.000000E+00
7         8.000000E+00
8         8.000000E+00
9         8.000000E+00
10        8.000000E+00
11        8.000000E+00
12        8.000000E+00
13        8.000000E+00
14        8.000000E+00
15        8.000000E+00
16        8.000000E+00
17        8.000000E+00
18        8.000000E+00
19        8.000000E+00
20        8.000000E+00
21        8.000000E+00
22        8.000000E+00
23        8.000000E+00
24        8.000000E+00
25        8.000000E+00
26        8.000000E+00
27        8.000000E+00
28        8.000000E+00
29        8.000000E+00
30        8.000000E+00
31        8.000000E+00
32        8.000000E+00
33        8.000000E+00
34        8.000000E+00
35        8.000000E+00
36        8.000000E+00
37        8.000000E+00
38        8.000000E+00
39        8.000000E+00
40        8.000000E+00
41        8.000000E+00
42        8.000000E+00
43        8.000000E+00
44        8.000000E+00
45        8.000000E+00
46        8.000000E+00
47        8.000000E+00
48        8.000000E+00
49        8.000000E+00
50        8.000000E+00
51        8.000000E+00
52        8.000000E+00
53        8.000000E+00
54        8.000000E+00
55        8.000000E+00
56        8.000000E+00
57        8.000000E+00
58        8.000000E+00
59        8.000000E+00
60        8.000000E+00
61        8.000000E+00
62        8.000000E+00
63        8.000000E+00
64        8.000000E+00
65        8.000000E+00
66        8.000000E+00
67        8.000000E+00
68        8.000000E+00
69        8.000000E+00
70        8.000000E+00
71        8.000000E+00
72        8.000000E+00
73        8.000000E+00
74        8.000000E+00
75        8.000000E+00
76        8.000000E+00
77        8.000000E+00
78        8.000000E+00
79        8.000000E+00
80        8.000000E+00
81        8.000000E+00
82        8.000000E+00
83        8.000000E+00
84        8.000000E+00
85        8.000000E+00
86        8.000000E+00
87        8.000000E+00
88        8.000000E+00
89        8.000000E+00
90        8.000000E+00
91        8.000000E+00
92        8.000000E+00
93        8.000000E+00
94        8.000000E+00
95        8.000000E+00
96        8.000000E+00
97        8.000000E+00
98        8.000000E+00
99        8.000000E+00
100       8.000000E+00
Sample files (sample.fem and sample.hwascii) are available at <Altair_installation>\hwdesktop\demos\mv_hv_hg\animation\hwascii\.
