Create Cached Results
Only the currently active contoured result may be added to the internal cache.
Create an internal cache of the active contour result using one of the following methods.
  • From the Contour panel panel, click Cache.
  • Right-click in the graphics area, or the browser white space, and select Create > Cached Result > Contour from the context menu.
Note: Whenever a result is cached, it is computed for each frame the first time a frame is loaded, thereby making the time taken for the first time load greater. The times for all subsequent loads will be significantly reduced.
