M2 Menu
The M2 menu contains options that set the correct element or load type and enter the appropriate HyperMesh panel.
Auxiliaries
FRICT
Enters the Components panel, selects the props collector, and sets card image = to FRICTION.
RUPMO
Enters the Components panel, selects the props collector, and sets card image = to RUPTURE_MODEL.
SENSO
Enters the Sensors panel.
CURVES
Enters the Edit Curves panel and sets the radio button to modify.
Safety
SLIPR
Sets element type mass = to SLIPRING and enters the Mass panel.
RETRA
Sets element type mass = to RETRACTR and enters the Mass panel.
BAGIN
Enters the Airbag panel and sets the card image to BAGIN.
CHAMB
Enters the Airbag panel and sets the card image to CHAMBER.
GASPC
Enters the Components panel, selects the props collector, and sets card image = to GASPEC.
Plot Output
THNOD
Enters the Output Blocks panel and changes the type to nodes.
THELE
Enters the Output Blocks panel and changes the type to elements.
SENPT
Sets element type mass = to SENPT and enters the Mass panel.
Nodals
FRAME
Enters the Systems panel.
NODE
Enters the Nodes panel.
INVEL
Sets load type velocity = to INVEL and enters the Velocity panel.
VEL3D
Sets load type velocity = to VEL3D and enters the Velocity panel.
RVE3D
Sets load type velocity = to REV3D and enters the Velocity panel.
ACC3D
Sets load type acceleration = to ACC3D and enters the Acceleration panel.
RDV3D
Sets load type velocity = to RDV3D and enters the Velocity panel.
RDA3D
Sets load type acceleration = to RDA3D and enters the Acceleration panel.
RAC3D
Sets load type acceleration = to RAC3D and enters the Acceleration panel.
BOUNC
Sets load type constraint = to BOUNC and enters the Constraints panel.
DIS3D
Sets load type constraint = to DIS3D and enters the Constraints panel.
DIS3DX
Sets load type constraint = to DIS3DX and enters the Constraints panel.
DIS3DM
Sets load type constraint = to DIS3DM and enters the Constraints panel.
RAN3D
Sets load type constraint = to RAN3D and enters the Constraints panel.
RDD3D
Sets load type constraint = to RDD3D and enters the Constraints panel.
CONLO
Sets load type constraint = to CONLO and enters the Constraints panel.
Analysis by Keywords
LOADCOLS
Enters the Collector panel, switches the type to loadcols and sets the card image to INVEL.
