Element Based Surface: Adjust Normal Tab
In the Adjust Normal tab, you can display and reverse normal direction for surfaces defined on 3D shell, membrane, rigid and 2D beam, pipe, and truss elements.
- (a) Reverse normal all
Table 1. Button Action Reverse Reverses normals of all faces for 3D shell, membrane, rigid elements and all contactsurfaces for 2D beam, pipe, truss elements in the current surface. Note: The normals of the underlying elements are not reversed. It reverses the normals of the faces or contactsurfaces only. - (b) Reverse normals: By element
Table 2. Button Action Element faces Opens the Element Selector panel. For 3D shell, membrane, rigid elements, pick the faces (not the underlying elements). However, for 2D beam, pipe, truss elements, pick the elements themselves as the contactsurfaces can not be picked from the graphic area. The corresponding Reset button resets the selected elements. Reverse Reverses normals of the selected faces for 3D shell, membrane, rigid elements and contactsurfaces of the selected 2D beam, pipe, truss elements. Note: The normals of the underlying elements are not reversed. It reverses the normals of the faces or contactsurfaces only.
Element Based Surface: Delete Face Tab
Use the Delete Face tab to delete faces or contactsurface from all elements types.
Surfaces can be displayed in two ways: by special face elements or by contactsurfaces. The surfaces defined on 3D solid, gasket, shell, membrane, rigid elements are displayed by face elements while surfaces on 2D solid, axisymmetric, gasket and all beam, pipe, truss elements are displayed by contactsurfaces.
This tab contains tools to find and delete duplicate faces for 3D solid, gasket, shell, membrane, or rigid elements.
- (a) All
Table 3. Button Action Delete Deletes all the faces or contactsurfaces in the current surface. - (b) By element
Table 4. Button Action Element Faces Opens the Element Selector panel. For 3D solid, gasket, shell, membrane, and rigid elements, pick the faces (not the underlying elements). However, for 2D solid, axisymmetric, gasket or all beam, pipe, truss elements, pick the elements themselves as the contactsurfaces can not be picked from the graphic area. The corresponding Reset button resets the selected elements. Delete Deletes the selected faces or contactsurfaces from the selected 2D solid, axisymmetric, gasket, beam, pipe, truss elements. - (c) Duplicate faces
Table 5. Button Action Find Duplicate Faces Finds duplicate faces, if any exists, for the current surface and highlights them in the graphic area. The status bar shows the number of duplicates found. The corresponding Reset button resets the selected elements. Delete Deletes the highlighted duplicate faces found. Note: Duplicate contactsurfaces cannot be added to the same surface in HyperMesh. Therefore, Duplicate Faces is only valid for 3D solid, gasket, shell, membrane, and rigid elements.
