Search and Find HyperMesh Tools
Quickly find and open the tools, panels, and browsers that are available from the menu bar pull-downs or from the Utility Browser, as well as create solver cards.
You can only create solver cards with the Quick Access tool in the Radioss, OptiStruct, Abaqus, LS-DYNA, PAM-CRASH 2G and Permas user profiles.
  1. Enable the Quick Access tool by pressing Ctrl + F.
    Once enabled, a search bar opens in the top, right of the application.
  2. Enter a search string.
    Predicted results appear in a list.
  3. Select a search result from the list, or press Enter to select the highlighted search result.
  4. Exit the Quick Access tool by pressing Esc or clicking anywhere outside of the tool.
Selecting a tool, panel, or browser from the list opens the respective tool.
Selecting a solver card from the list creates a new card.
Tip: When creating solver cards with the Quick Access tool, set the Model Browser as the current tab so that you can easily recognize where newly created cards are being stored upon creation.
Figure 3.
