Organize Settings
Determine which dependent entities to move when managing subsystem content and behavior if entities are shared across subsystems.
When moving an entity into a subsystem, there are customizable options that determine which dependent entities would also be organized into the subsystem. For example, moving a component by default will also move the associated nodes, elements, properties and materials.
There are secondary options that determine the action if the entity is shared (has multiple references). For example, when moving a property, should the material should also move to the subsystem if a different property also references the same material?
When moving an include, organize settings are ignored, and only the include content is moved.
To access these settings, right-click in the Subsystem Browser and select Organize Settings from the context menu.
