HyperMesh
HyperMesh
2021
  1. Home
  2. Browsers
    Browsers supply a great deal of view-related functionality in HyperMesh by listing the parts of a model in a tabular and/or tree-based format, and providing controls inside the table that allow you to alter the display of model parts.
  3. Basic Browser Operations
    Learn the basics of working with browsers.
  4. Find and Search for Entities
    The search bar can be used to find and filter entities in a browser.
  • What's New
  • Get Started
  • Tutorials
  • CAD Interfaces
  • Browsers
  • Panels
  • Geometry
  • Meshing
  • Connectors
  • Model Build and Assembly
  • Model Verification
  • Crash and Safety
  • Composites
  • Model Setup
  • Morphing
  • Optimization
  • Conversion Between Solver Formats
  • XY Plotting
  • Post-Processing Analysis
Index
 HyperMesh
2021
HyperMesh
  • What's New
    View new features for HyperMesh 2021.
  • Get Started
  • Tutorials
    Discover HyperMesh functionality with interactive tutorials.
  • CAD Interfaces
  • Browsers
    • Basic Browser Operations
      • Sort Entities
        Sort the entities within a folder.
      • Find and Search for Entities
      • Display Controls and Browser Modes
        These controls affect which entities display in the graphics area, and how they display, such as shaded or wireframe.
      • Context Menu
        A context menu of actions is available for any selected item in the browser.
    • Assembly Browser
      Use the Assembly Browser to manage parts and modules during the assembly building process.
    • Connector Browser
      Use the Connector Browser to view and modify connectors in the current model.
    • Contact Browser
      Use the Contact Browser to create, review and modify contact interfaces and surfaces in a model.
    • Entity Editor
      The Entity Editor enables you to quickly view and edit entities in a model and correctly setup solver information.
    • Entity State Browser
      Use the Entity State Browser to set various states for entities in a model.
    • Loadsteps Browser
      Use the Loadsteps Browser to create, manage and display loadsteps (sub-cases) and the associated control cards.
    • Mask Browser
      In the Mask Browser, set the mask/unmask state for entities at the entity configuration level.
    • Mass Trimming Browser
      Use the Mass Trimming tool to create, define and realize mass entities.
    • Matrix Browser
      Use the Matrix Browser to explore the HyperMesh and HyperView data entities and export the entities to external files for further analysis.
    • Model Browser
      Use the Model Browser to view the model structure while providing full find, display and editing control of entities.
    • Model Checker
      Check the solver validity of the model, identify modeling issues, and fix modeling issues in an automatic or manual way.
    • Part Browser
      Use the Part Browser to create, organize and manage the CAE part structure/hierarchy.
    • Reference Browser
      The Reference Browser enables you to quickly understand complex relationships between different entities that constitute the model.
    • Solver Browser
      The Solver Browser provides a solver centric view of the model structure in a flat, listed tree structure.
    • Subsystem Browser
      Create, organize and manage the CAE subsystem level models using any entities.
    • Utility Menus
      The Utility menu contains options that allow you to customize the standard interface to include function buttons, radio options, and text that have HyperMesh-supplied and user-defined macros associated with them.
    • Visualization Controls
      Use the Visualization controls to change many of the visual states in HyperMesh and HyperView.
  • Panels
  • Geometry
  • Meshing
  • Connectors
  • Crash and Safety
  • Composites
    HyperMesh composites modelings.
  • Model Setup
  • Morphing
  • Optimization
  • XY Plotting
 HyperMesh
HyperMesh
2021
  1. Home
  2. Browsers
  • What's New
  • Get Started
  • Tutorials
  • CAD Interfaces
  • Browsers
  • Panels
  • Geometry
  • Meshing
  • Connectors
  • Crash and Safety
  • Composites
  • Model Setup
  • Morphing
  • Optimization
  • XY Plotting
Index
Perform a Quick Search
  1. Enter the Name or ID directly in the browser search bar.
    Entering this query Returns this result
    shell All entities that contain shell in their name.
    "shell" All entities with the name shell.
    shell* All entities starting with the name shell.
    *shell All entities ending with the name shell.
    *shell* All entities that contain shell in their name.
    2 or "2" All entities with the ID 2.
    1-4 All entities with the IDs in range 1 to 4.
    1,5,9 All entities with the IDs 1, 5 and 9.
  2. Press Enter or click to execute the search.
  3. Clear the search and return to the default browser view in the following ways:
    • Delete the search and press Enter.
    • Click x.
    • With the cursor's focus on the search bar, press Esc.
Tip: When the entry is alpha or alpha-numeric, the searched is performed on the names of entities. When the entry is only numeric, the searched is performed on the IDs of entities.
Perform an Advanced Search Using Auto-Completion
Interactively build search strings using a dynamic suggestion list.
  1. Access the list by clicking the text field of a browser search bar.
  2. Select attributes, operators, and values to append the correct syntax to the search string.
    The search syntax follows this basic form: <attribute> <operator> <value>.
    Figure 3.
    Note: The attributes available in the list are the same as the current active browser attributes (columns). If you don't see an expected attribute, make sure the corresponding browser column is turned on.
    Name~Bpillar All entities that contain Bpillar in their name.
    Name!~Bpillar All entities that do NOT contain Bpillar in their name.
    Name=Bpillar All entities with the name Bpillar.
    ID=10 All entities with an ID equal to 10.
    ID!=10 All entities with an ID not equal to 10.
    Entity=Components AND ID>10 Components with an ID greater than 10.
    Entity=Components OR ID>10 All Components and other entities with an ID greater than 10.
    ID>=10 AND ID=<20 AND Name~Bpillar All entities that contain Bpillar in their name and have an ID greater than or equal to 10 and less than or equal to 20.
    Include=1 AND Material E=210000 OR Material E=220000 Materials with E=210000 under Include1 and Materials with E=220000 under all other includes.
    Include=1 AND (Material E=210000 OR Material E=220000) Materials with E=210000 and E=220000 under Include1.
    Include=1 AND Material E IN(210000,220000) Materials with E=210000 and E=220000 under Include1.
    Include=1 AND Property T NOT IN(1.5,3.5) Properties with Thickness not equal to 1.5 or 3.5 under Include1
  3. Press Enter or click to execute the search.
  4. Clear the search and return to the default browser view in the following ways:
    • Click x.
Tip:
  • Press the Down Arrow key to scroll thought the list of attributes, operators, or values.
  • Press Tab or Enter to select the attributes, operators, or values
  • Press Esc to dismiss the list of attributes, operators, or values.
  • While searching for text with space or special characters, use quotes (“ ”).
  • To search multiple values with a single attribute entry, use a coma after the first value selection without a space.
  • Double-click on an attributes, operators, or values to invoke suggestion list.
Use Column Filters to Build a Search
Use column filters to quickly search any attribute that is added to a browser as a column.
Column filters are only supported in entity specific views.
  1. Hover over a column name then click the filter icon .
  2. Type a value or select from the suggestion list then press Enter or click .
    The value entered is converted to the correct syntax and shown in the search bar.
    Figure 4.
    You can also use operators in the column filter to refine the search.
    Figure 5.
    A column filter icon indicates the column on which the filter is applied.
    Figure 6.
    Multiple column filters can be applied. The search string is appended in the search bar.
    Figure 7.
    • Click x.
Use Predefined Filters to Build a Search
Use predefined filters to quickly filter the browser contents with selected or displayed entities
Predefined filters are supported in Model Browser entity views, the Part Browser, and the Subsystem Browser.
  1. Access the list of predefined filters by clicking the drop-down button next to the search icon.
    Figure 8.
    • Selected - Filters the browser with just the selected items. The Selected filter works for selection in both the browser and the graphics and should be reapplied after appending an existing selection.
    • Displayed - Filters the browser with entities that are displayed in the graphics. When the Displayed filter is applied in a browser, the filtered results are automatically updated upon changing the display state of the selected entities.
    • Current - Filters out the current collector.
  2. Clear the search and return to the default browser view in the following ways:
    • Click x.
Tip: After applying predefined filters, the search string can be further appended with more arguments to refine the search results.
Access Recent Search Strings
Click the text field of a browser search bar.
Your recent searches are indicated by the icon.
Figure 9.
Clicking on a recent search string auto-applies the filter and shows the search string in the search bar.
Clicking Remove removes the selected search string from recent history.
Note: A maximum of 5 recent searches are shown. Remove the latest strings to see previous search strings.
