Design variables are only supported for the OptiStruct
and Nastran user profiles.
Create design variable.
- In the browser, right-click on a sub-type under
the design variable branch and select New from the
context menu.
the design variable branch, then select New from the
File menu.
the design variable branch, then click (New)
on the toolbar.
Only sub-type available is DESVAR.
A new design variable appears under the selected branch.
A default name and ID are assigned to newly created design variable.
The newly created design variable is automatically selected in the Laminate
browser and the Define/Edit pane takes on the appropriate configuration.
If desired, a new name for the laminate may be entered in the Desvar
field.
Initial, lower bound, and upper bound values for the design variable can be
entered in the appropriate data fields.
Checking the Move limit box activates the Move limit
field, where a move limit value other than the default of 0.5 may be
entered.
Checking the Ddval ID box activates the Ddval ID field,
where the ID of a discrete value list may be entered.
Click Apply to save the
changes for the current HyperLaminate session.
Note: The HyperMesh database is only updated on exit
from HyperLaminate.
