Define Representations
Create your own user defined representation. User defined representations are saved to the settings and will be available in subsequent HyperMesh sessions.
  1. In the Part Browser, right-click on part assemblies or parts and select Representations > Settings > User Representations from the context menu.
  2. In the User Representation dialog, click + to add a new representation.
  3. In the Representation field, enter a name for the representation.
  4. In the Param File and Criteria File fields, select the appropriate mesh parameter and criteria file.
  5. If the representation is for solids, select the Solid checkbox.
  6. Click OK.
