Browsers supply a great deal of view-related functionality in HyperMesh by listing the parts of a model in a tabular and/or tree-based format, and providing controls inside the table
that allow you to alter the display of model parts.
Smooth Particle Hydrodynamics (SPH), Finite Point Method (FPM) is a technique used to analyze bodies that do not have
high cohesive forces among themselves and undergo large deformation, such as liquids and gases.
1D mesh that allows accurate testing of connectors, such as bolts, and similar rod-like or bar-like objects that can
be modeled as a simple line for FEA purposes.
The mesh generation algorithms are divided into two types: those that require the presence of a surface to provide
a context of operation, or those working entirely from node and/or line data.
Most of the surface-less mesh generation algorithms require that some edges have exactly the same element density
and biasing values as other edges. Those edges are automatically linked together so that they stay balanced.
Automatically generate a mesh at the midplane location, directly from the input geometry (components, elements, solids
or surfaces), without first creating a midsurface.
Shrink wrap meshing is a method to create a simplified mesh of a complex model when high-precision models are not
necessary, as is the case for powertrain components during crash analysis.
2D BL meshing is a method to create a 2D mesh with or without boundary layers on planar sections defined by sets/groups
of edges defining closed loops.
Volume mesh or "solid meshing" uses three-dimensional elements to represent fully 3D objects, such as solid parts
or sheets of material that have enough thickness and surface variety that solid meshing makes more sense than 2D shell
meshing.
Perform automatic checks on CAD models, and identify potential issues with geometry that may slow down the meshing
process using the Verification and Comparison tools.
The mesh type determines the type of elements used to create mesh during automatic
meshing.
Advanced
Enables you to select a Mapped Type for elements on surfaces that can be mapped to
simple geometric shapes and a Free Type for elements that cannot easily be mapped to
simple shapes to use when creating mesh.
Mixed
Uses quad elements to create mesh, but inserts tria elements when making density
transitions to improve mesh quality. Figure 1. Mixed
Quads
Uses quad elements to create mesh, however if the sum of the element densities around
the perimeter of the face or surface is odd then at least one tria element must be
created. Adjusting the element densities while meshing interactively can usually
eliminate all tria elements. Figure 2. . The sum of element densities on the perimeter of the lower surface is odd,
resulting in a tria as indicated. Figure 3. . Adjusting the bottom edge density from 11 to 10 makes the sum even and
generates all-quads.
Quads Only
Uses a subdividing routine that tends to generate more orthogonal quad elements to
create mesh. Tria elements may still used depending on the density settings as with
the quads type. Figure 4. Quads Only
R-Trias
Uses right-angle triangular elements to create mesh. Figure 5. R-Trias
Trias
Uses all tria elements to create mesh. Figure 6. Trias
