Create and Edit Assigned Entities
Create, edit, and assign new entities to an existing entity or group of entities in the Entity Editor.
Create and Assign a New Entity
To create and assign a new entity to an existing entity or a group of entities:
![](../../images/icons/icon_hamburger_menu.png)
- Create - Define a new entity using an embedded Entity Editor.
- Create/Edit - Define a new entity using a standalone Entity Editor.
Edit an Assigned Entity
To edit an entity that is assigned to an existing entity or a group of entities, do one of the following:
Click
next to an entity assignment field. In the embedded Entity Editor, modify the entity data. When you are finished making changes, click
to collapse the editor.
Right-click on an entity assignment field, or click
, then select Edit from the context menu. Modify the entity data using the standalone Entity Editor. When you are finished making changes, click Close.
