Other Methods for Fitting a Curve
The following methods require certain parameters other than UTS to define the SN/EN curve.
  1. From the Assign Material dialog, click the My Material tab and select your created material.
  2. Select an input method.
  3. Click to view the model description.
  4. Define any necessary parameters.
    Note: The images below use the default values as a guideline.
SN Properties
Figure 1. Point, 1-seg
Figure 2. Point, 2-seg
Figure 3. Slope-intcept, 1-seg
Figure 4. Slope-intcept, 2-seg
Figure 5. Slope-trans, 1-seg
Figure 6. Slope-trans, 2-seg
EN Properties
Figure 7. Slope
