Create an Order (scaled) vs. an RPM Waterfall Plot
  1. From the HyperGraph 3D toolbar, click the Waterfall icon, .
  2. Under Plot type:, select Order (scaled) from the first drop-down menu and Input magnitude from the second drop-down menu.
  3. Under Data curves:, enter a p#w#c#.vector curve reference in the Response= field manually, or press Shift and left-click an RPM curve in HyperGraph 3D.
Or
  1. Use the curve selector.
    1. Click the curve selection button, , in the Response text box to display the Response dialog.
    2. Choose a curve from the tree and click Select.
    3. You can also click Preview to view the curve before selecting it.
    4. Click Close to close the Response dialog.
  2. Under Data curves:, enter a p#w#c#.vector curve reference in the Input= field manually, or press Shift and left-click an RPM curve in HyperGraph 3D. Or, use the curve selector. See Step 3.
  3. Under Waterfall slices:, select Number: and enter the number of slices for the waterfall plot.
Or
  1. Select Step size: and enter a step size based on the time vector of the response curve.
  2. Click Apply.
