HyperGraph 3D Context Sensitive Menu
From the HyperGraph 3D modeling window, right-click to display the context menu.
Figure 1. HyperGraph 3D Context Menu
Axes
Choose from the following options from the Axes submenu:
Box
Displays the Box grid style. This is the default.
Lines
Displays the Line grid style. If you select Lines, and right-click on the axis again, a different context menu is displayed. This menu displays options also found on the Axes panel.
Click Edit to display the Axes panel.
Click Label to display the Axis Label micro dialog. Edit the axis label and click OK.
Figure 3.
Click Min or Max to display the Axis Maximum or Minimum micro dialog. Enter a new value and click OK.
Figure 4.
Chart
Displays the chart grid style.
Cubical
The displayed length of each axis is the same.
Unscaled
The displayed length of each axis is based on the axes values.
Best Fit
Adjusts the length of the axes to maximize the graphics area.
Locked
Locks the lengths of the axes so that they are not rescaled.
Background
Select a color for the background of the 3D plot. Select Custom to customize the color.
Frame
Select a color for the area surrounding the 3D plot. Select Custom to customize the color.
Gridlines
Select a color for the gridlines of the 3D plot. Select Custom to customize the color.
Contour
Choose from the following options on the Contour submenu. On and Discrete are the defaults.
On/Off
Turn the contour on or off.
Off is the default.
Discrete/Blended
Select Discrete or Blended for the contour.
Discrete is the default.
Recalculate
Forces the plot to regenerate all calculated data and reread all file data.
Legend
You can turn the legend on or off. On is the default.
Shading
Choose from the following options on the Shading submenu:
Smooth
The edges are smooth. This is the default.
Flat
The edges are flat.
Fit
Zooms in or out to fit the curve's maximum and minimum values to the axes.
