Change the Curve Color
  1. From the HyperGraph 3D Curve Attributes panel, select the Surface tab.
  2. Deactivate the Contour checkbox, if necessary.
  3. Select a curve or curves from the Curves list.
  4. From the color palette, select the new color for the curve.
