HyperWorksEngineering Solutions is a modeling and visualization environment for NVH, Crash, CFD, Drop Test and Aerospace using best-in-class solver
technology.
The Crash application offers a tailored environment in HyperWorks that efficiently steers the Crash CAE specialist in CAE model building, starting from CAD geometry and finishing with
a runnable solver deck in Radioss, LS-DYNA and PAM-CRASH 2G.
HyperWorks offers high quality tools for CFD applications enabling the engineer to perform modeling, optimization and post-processing
tasks efficiently.
The Drop Test Manager is an automated solution that allows you to either simulate a single drop test or a choice of
multiple iterations with the aim of finding the sensitivity of process variables like initial orientation and drop
height in a typical drop test by controlling the run parameters and conditions with ease.
Many essential utility tools using HyperWorks-Tcl have been developed over the years to support Aerospace customers. A few tools have been collected and upgraded to
be compatible with this release.
Browsers supply a great deal of view-related functionality in Engineering Solutions by listing the parts of a model in a tabular and/or tree-based format, and providing controls inside the table
that allow you to alter the display of model parts.
Perform automatic checks on CAD models, and identify potential issues with geometry that may slow down the meshing
process using the Verification and Comparison tools.
All entities in a HyperMesh database are stored in collectors. Based on the assigned template, each collector may use a dictionary or card image to define the attributes assigned to the collector. The definitions contained in the dictionaries or card image are used to translate models to external analysis codes.
Control cards allow you to add input and output parameters to a model, including location and names of the input,
output and scratch files; the type of run (analysis, check or restart); overall running of the analysis or optimization;
and type, format and frequency of the output.
Each surface contains one or more faces. It is usually preferable to combine multiple
faces into one surface entity before you use the meshing tools.
This allows them to be meshed at the same
time.
Use the Surface Edit panel to modify surface geometry when it is necessary to
make changes before you generate a mesh.
For example, to trim a surface with a line, use the trim with lines subpanel
of the Surface Edit panel. You must select the surface and the line and
specify a direction vector. The surface is trimmed by sweeping the line
along the vector and intersecting the surface with the sweep. If the sweep
does not intersect the surface, the surface is not trimmed.
Figure 1. . A circle and a surface (represented with surface lines) before
trimming.
Figure 2. . After the circle is used to trim the surface, two new surfaces are
created (shown highlighted) and the original surface is
trimmed.
To trim one surface with another, use the trim with surfs/planes
subpanel.
Figure 3. . Two surfaces before trimming.
Figure 4. . The smaller surface is split into two surfaces after it is trimmed
with the larger surface.
