HyperWorksEngineering Solutions is a modeling and visualization environment for NVH, Crash, CFD, Drop Test and Aerospace using best-in-class solver
technology.
The Crash application offers a tailored environment in HyperWorks that efficiently steers the Crash CAE specialist in CAE model building, starting from CAD geometry and finishing with
a runnable solver deck in Radioss, LS-DYNA and PAM-CRASH 2G.
HyperWorks offers high quality tools for CFD applications enabling the engineer to perform modeling, optimization and post-processing
tasks efficiently.
The Drop Test Manager is an automated solution that allows you to either simulate a single drop test or a choice of
multiple iterations with the aim of finding the sensitivity of process variables like initial orientation and drop
height in a typical drop test by controlling the run parameters and conditions with ease.
Many essential utility tools using HyperWorks-Tcl have been developed over the years to support Aerospace customers. A few tools have been collected and upgraded to
be compatible with this release.
Browsers supply a great deal of view-related functionality in Engineering Solutions by listing the parts of a model in a tabular and/or tree-based format, and providing controls inside the table
that allow you to alter the display of model parts.
A part is an engineering representation of a physical part, and a part assembly is a group of part assemblies and/or
parts. Part Instances, which are recognized from PDM, are automatically converted to Part Instances on import into
HyperMesh.
The part assembly can be saved as a self-contained binary file, which will include the part assembly based hierarchy
and attributes such as components, properties, and materials.
The CAD representation is typically the original source of information of what a physical part will look like. It
forms the basis of the Common representation, which in turn is the basis of all subsequent discipline specific mesh
representations. A part can contain multiple representations.
Create your own user defined representation. User defined representations are saved to the settings and will be available
in subsequent HyperMesh sessions.
Parts and part assemblies without a UID cannot be saved to the Library. Considering this, the UID field in the Save Representation dialog is user editable.
Perform automatic checks on CAD models, and identify potential issues with geometry that may slow down the meshing
process using the Verification and Comparison tools.
Part Assemblies can also be saved to the Library. This saves all parts as one Part
Assembly representation rather than individual Part representations. This enables
mesh connectivity between parts to be retained upon unloading and loading of the
Part Assembly.
In the Part Browser, right-click on part assemblies and
select Representations > Save from the context menu.
The Save Representation dialog
displays.
Change the Parts selection in the bottom left to Part Assemblies.
Edit the Major Revision and Study
Revision columns to reflect the intended revisions.
Select the Representation type.
To overwrite representations that already exist in the repository, select the
Overwrite available checkbox.
To only save parts locally, deselect the Save to Library
checkbox.
