HyperWorksEngineering Solutions is a modeling and visualization environment for NVH, Crash, CFD, Drop Test and Aerospace using best-in-class solver
technology.
The Crash application offers a tailored environment in HyperWorks that efficiently steers the Crash CAE specialist in CAE model building, starting from CAD geometry and finishing with
a runnable solver deck in Radioss, LS-DYNA and PAM-CRASH 2G.
Manage all of the IDs for the entities that you create, and define ID ranges for all of the entities in each Include
file in relation to the full model in order to avoid ID duplication.
Lists various options to define animation and time history outputs in the model for post-processing. Accordingly, they
are broadly classified into three sections as Animation, Time History and Checks.
HyperWorks offers high quality tools for CFD applications enabling the engineer to perform modeling, optimization and post-processing
tasks efficiently.
The Drop Test Manager is an automated solution that allows you to either simulate a single drop test or a choice of
multiple iterations with the aim of finding the sensitivity of process variables like initial orientation and drop
height in a typical drop test by controlling the run parameters and conditions with ease.
Many essential utility tools using HyperWorks-Tcl have been developed over the years to support Aerospace customers. A few tools have been collected and upgraded to
be compatible with this release.
Browsers supply a great deal of view-related functionality in Engineering Solutions by listing the parts of a model in a tabular and/or tree-based format, and providing controls inside the table
that allow you to alter the display of model parts.
Perform automatic checks on CAD models, and identify potential issues with geometry that may slow down the meshing
process using the Verification and Comparison tools.
After loading the Radioss user profile and importing a
Radioss model, run the conversion macro by clicking Tools > Conversion > PAMCRASH. The Conversion tab opens.
In the Destination template field, select the destination solver version.
Click Convert to start the conversion. After conversion, the
selected version of the PAM-CRASH 2G user profile is
automatically loaded.
Review and export the deck using the PAM-CRASH 2G user
profile.
Some of the keywords in the Radioss deck are converted to the
PAM-CRASH 2G deck as per the following table:
Element Mapping
Engineering Solutions configuration, Radioss type
Engineering Solutions configuration, PAM-CRASH 2G type
TRUSS
BAR
BEAM
BEAM
SPRING
SPRING
SPRING+PROP/SPR_BEAM (TYPE 13)
SPRBM
SH3N
SHELL
SHELL
SHELL
BRICK
SOLID
TETRA44
TETRA44
ADMAS
MASS
SPRING+INTER/TYPE2
PLINK
SPRING+PROP/KJOINT(TYPE33)
KJOIN
RBODY
RBODY
Boundary Conditions Mapping
INIVEL
INVEL
BCS
BOUNC
CLOAD
CONLO
System Mapping
FRAME/FIX
FRAME
SKEW/MOV
FRAME
SKEW/FIX
FRAME
Material Mapping
M1_ELASTIC
MAT_1D TYPE 201, MAT_2D TYPE 101
/PROP/SPRING
MAT_1D TYPE 220
/PROP/SPR_BEAM
MAT_1D TYPE 223
M0_VOID
MAT_2D TYPE 100
M36_PLAS_TAB
MAT_2D TYPE 102/103
M44_COWPER
MAT_2D TYPE 102/103
M2_PLAS_JOHNS
MAT_2D TYPE 102/103
Property Mapping
PROP/BEAM
PART, TYPE= BEAM
PROP/KJOINT
PART, TYPE = KJOIN
PROP/SHELL
PART, TYPE = SHELL
PROP/SOLID
PART, TYPE = SOLID
PROP/SPRING
PART, TYPE = SPRING
PROP/SPR_BEAM
PART, TYPE = SPRING
PROP/SPR_GENE
PART, TYPE = SPRING
PROP/TRUSS
PART, TYPE = BAR
Curve Mapping
FUNCT
FUNCT
Control Cards Mapping
TITLE
TITLE
OCTRL/
DSYOUPUT
/ANIM/DT
THPOUTPUT
/TFILE
Component Mapping
PART
PART
Contact Interface Mapping
CNTAC36
INTER/TYPE7
Rigid Wall Mapping
RWALL
RWALL
Time History Definition Mapping
TH/SPRING
THELE
TH/NODE
THNODE
TH/FRAME
THLOC
Section Definition Mapping
SECT
SECFO
Group Definition Mapping
GRNOD/NODE
GROUP
GRNOD/GENE
GROUP
GRNOD/SUBSET
GROUP
GRNOD/PART
GROUP
GRNOD/MAT
GROUP
GRNOD/PROP
GROUP
GRNOD/GRNOD
GROUP
GRNOD/SURF
GROUP
GRNOD/GRSHEL
GROUP
GRNOD/GRBRIC
GROUP
GRNOD/GRSPRI
GROUP
GRNOD/GRSH3N
GROUP
GRNOD/GRTRUS
GROUP
GRNOD/GRBEAM
GROUP
GENOD/NODENS
GROUP
GRNOD/FORMULA
GROUP
Airbag Definition Mapping
BAGIN
MONVOL
The attributes converted in each KEYWORD is explained in the
Conversion dialog. Each keyword is associated with a color to
distinguish it better.
Green
All the attributes of the KEYWORD are converted to equivalent in
PAM-CRASH 2G.
Orange
Only some of the attributes of the KEYWORD are converted to equivalent in PAM-CRASH 2G.
Red
None of the attributes of the KEYWORD are converted to equivalent in PAM-CRASH 2G. Basically conversion of this keyword is not
supported by the conversion tool.
