Create Single Component
Opens a dialog to create a single component.
Create CFD Components
Functionality to define the standard CFD collectors. In the dialog, the commonly
used collectors names, such as inflow, are pre-selected. Components can be added or
removed from the list and a multiplier for each component can be defined. By clicking
Create the selected components are created and appear in the Model Browser.
Delete
Delete data from a model database, preview and delete empty collectors, and preview
and delete unused property collectors, material collectors or curves.
Edges
Find the free edges in a group of elements, find "T" or discontinuous connections in
a group of elements (any edges connected to three or more elements), display duplicate
nodes and equivalence duplicate nodes.
Edit Element
Hand-build, combine, split or modify elements.
Element Types
Select the type of element to create and also allows you to change existing element
types.
Faces
Opens the Faces panel. This panel is used to generate the bounding or exterior
surface elements (^faces collector) that will be used to define surface zones for the
different boundary conditions.
Hidden Line
Create hidden line plots of the displayed structure. Also contains the Clip Boundary
Elements tool, which allows you to visually sweep the cutting section for greater
viewing clarity.
Organize
Reorganize your database by copying or moving data (entities) among collectors or
includes.
