Apply a Contour to a Streamline
  1. From the Streamlines panel, follow the steps to create a line rake/streamline, area rake/streamline or plane rake/streamline.
  2. Go to the Contour panel.
  3. Select a result type from the Result type drop-down menu.
  4. Click Apply.
    The contour is applied to the streamline.
    Note: HyperView supports streamline contouring for nodal results only (elemental results are currently not supported).
