Use Record View
A dynamic view of the model including display options.
- Open/import an existing HyperMesh model.
From the menu bar, click .
- Start: Make your selections in the File Recorder dialog. Click Start. The record view execution starts in the background.
- End: End the Record View tool. The file gets saved to the user-defined location, which you can use in the model summary report.
- Play: Record View file player. You can select the file to run on the model. The execution saved command is executed in the background.
